HP 15-d076nr Fan Replacement
    1. HP 15-d076nr Fan Replacement, Battery: step 1, image 1 of 1
      • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
      • Locate the left and right switches at the bottom of the laptop.
      Ask FixBot
    2. HP 15-d076nr Fan Replacement: step 2, image 1 of 1
      • Move the right switch to the left so that the orange unlock symbol is showing.
      Ask FixBot
    3. HP 15-d076nr Fan Replacement: step 3, image 1 of 1
      • Move the left switch to the right, covering the battery symbol, and hold.
      Ask FixBot
    4. HP 15-d076nr Fan Replacement: step 4, image 1 of 1
      • While holding the left switch in place, slide the battery towards you and away from the laptop.
      Ask FixBot
    1. HP 15-d076nr Fan Replacement, Wireless Card: step 5, image 1 of 1
      • Re-orient the laptop, so that the back of the laptop faces away from you.
      Ask FixBot
    2. HP 15-d076nr Fan Replacement: step 6, image 1 of 1
      • Locate the small screw on the panel at the center of the laptop.
      • Loosen the small screw using a Philips # 1 screwdriver.
      • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
      Ask FixBot
    3. HP 15-d076nr Fan Replacement: step 7, image 1 of 2 HP 15-d076nr Fan Replacement: step 7, image 2 of 2
      • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
      • Pull the panel away from the laptop and set it off to the side.
      Ask FixBot
    4. HP 15-d076nr Fan Replacement: step 8, image 1 of 2 HP 15-d076nr Fan Replacement: step 8, image 2 of 2
      • Gently wiggle and lift the black antenna wire away from the wireless card.
      • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
      Ask FixBot
    5. HP 15-d076nr Fan Replacement: step 9, image 1 of 3 HP 15-d076nr Fan Replacement: step 9, image 2 of 3 HP 15-d076nr Fan Replacement: step 9, image 3 of 3
      • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
      • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
      Ask FixBot
    6. HP 15-d076nr Fan Replacement: step 10, image 1 of 1
      • Slide the wireless card to the left to remove it from the socket.
      Ask FixBot
    1. HP 15-d076nr Fan Replacement, Motherboard: step 11, image 1 of 1
      • Locate the RAM in the exposed area.
      Ask FixBot
    2. HP 15-d076nr Fan Replacement: step 12, image 1 of 3 HP 15-d076nr Fan Replacement: step 12, image 2 of 3 HP 15-d076nr Fan Replacement: step 12, image 3 of 3
      • Locate the latches on the RAM.
      • Slide the latches away from the RAM using a plastic spudger.
      • The RAM might spring out.
      Ask FixBot
    3. HP 15-d076nr Fan Replacement: step 13, image 1 of 1
      • Remove the RAM.
      Ask FixBot
    4. HP 15-d076nr Fan Replacement: step 14, image 1 of 3 HP 15-d076nr Fan Replacement: step 14, image 2 of 3 HP 15-d076nr Fan Replacement: step 14, image 3 of 3
      • Locate the ribbon cables.
      • Pry up the black tabs on the connectors and disconnect both of the ribbon cables.
      Ask FixBot
    5. HP 15-d076nr Fan Replacement: step 15, image 1 of 2 HP 15-d076nr Fan Replacement: step 15, image 2 of 2
      • Locate the DVD drive screw.
      • Remove the Phillips PM2.5×6.5 screw using a Phillips #0 screwdriver.
      • Continue using a Phillips #0 screwdriver for the rest of this guide, and subsequent guides.
      • Take the screw and place it in a container so as to not lose it.
      Ask FixBot
    6. HP 15-d076nr Fan Replacement: step 16, image 1 of 2 HP 15-d076nr Fan Replacement: step 16, image 2 of 2
      • Push down the tab that is located by the DVD drive screw.
      • Take the DVD drive in one hand, and using the plastic spludger, push the tab down, and out.
      Ask FixBot
    7. HP 15-d076nr Fan Replacement: step 17, image 1 of 2 HP 15-d076nr Fan Replacement: step 17, image 2 of 2
      • Remove the fourteen Phillips PM2.5×6.0 screws, and place them in a separate container.
      Ask FixBot
    8. HP 15-d076nr Fan Replacement: step 18, image 1 of 3 HP 15-d076nr Fan Replacement: step 18, image 2 of 3 HP 15-d076nr Fan Replacement: step 18, image 3 of 3
      • Flip the laptop over, and open it as if you were using it.
      • Gently, remove the laptop cover/keyboard from the laptop using the plastic spudger.
      • When you remove the cover/keyboard, the laptop will become top heavy.
      Ask FixBot
    9. HP 15-d076nr Fan Replacement: step 19, image 1 of 1
      • Disconnect the monitor cable, using the plastic spudger, and pry it upwards.
      • Pull the cable from its routing until it is free.
      Ask FixBot
    10. HP 15-d076nr Fan Replacement: step 20, image 1 of 2 HP 15-d076nr Fan Replacement: step 20, image 2 of 2
      • Lift the black tabs, and disconnect the three ribbon cables.
      • Disconnect the red-black-white speaker cable located in the lower left corner.
      Ask FixBot
    11. HP 15-d076nr Fan Replacement: step 21, image 1 of 2 HP 15-d076nr Fan Replacement: step 21, image 2 of 2
      • Remove the three Phillips PM2.5×4.0 screws on the card reader in the bottom left corner.
      • Place the screws in a separate container.
      • Remove the card reader.
      Ask FixBot
    12. HP 15-d076nr Fan Replacement: step 22, image 1 of 2 HP 15-d076nr Fan Replacement: step 22, image 2 of 2
      • Remove the five Phillips PM2.5×5.0 screws on the motherboard.
      Ask FixBot
    13. HP 15-d076nr Fan Replacement: step 23, image 1 of 1
      • Remove the Phillips PM2.5×5.0 screw located on the fan, in the upper right corner.
      Ask FixBot
    14. HP 15-d076nr Fan Replacement: step 24, image 1 of 2 HP 15-d076nr Fan Replacement: step 24, image 2 of 2
      • Carefully lift up the motherboard.
      • Do not completely remove the motherboard. Simply lift it. There is a black cable on the bottom of the motherboard that is anchoring it.
      Ask FixBot
    15. HP 15-d076nr Fan Replacement: step 25, image 1 of 1
      • Locate the cable on the underside of the motherboard, in its lower right corner.
      • Carefully grip the cable, and pull downward to remove it.
      Ask FixBot
    16. HP 15-d076nr Fan Replacement: step 26, image 1 of 1
      • Flip the motherboard over.
      Ask FixBot
    17. HP 15-d076nr Fan Replacement: step 27, image 1 of 1
      • Locate the charge port cable connection point on the motherboard.
      • Grab the charge port cable's connector, and wiggle it to remove it.
      • Set the board off to the side.
      Ask FixBot
    1. HP 15-d076nr Fan Replacement, Fan: step 28, image 1 of 2 HP 15-d076nr Fan Replacement, Fan: step 28, image 2 of 2
      • Carefully loosen the four screws on the processor heat sink.
      • The screws do not come out. They are retained by the heat sink.
      Ask FixBot
    2. HP 15-d076nr Fan Replacement: step 29, image 1 of 1
      • Disconnect the red-yellow-blue-black cable, next to the fan, on the motherboard.
      • You may need to wiggle it
      Ask FixBot
    3. HP 15-d076nr Fan Replacement: step 30, image 1 of 1
      • Remove the fan.
      Ask FixBot
Mohiuddin Baig
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 103
All Time: 1,075
