HP 15-d076nr Charge Port Replacement
  1. HP 15-d076nr Charge Port Replacement, Battery: step 1, image 1 of 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
    Ask FixBot
  2. HP 15-d076nr Charge Port Replacement: step 2, image 1 of 1
    • Move the right switch to the left so that the orange unlock symbol is showing.
    Ask FixBot
  3. HP 15-d076nr Charge Port Replacement: step 3, image 1 of 1
    • Move the left switch to the right, covering the battery symbol, and hold.
    Ask FixBot
  4. HP 15-d076nr Charge Port Replacement: step 4, image 1 of 1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
    Ask FixBot
  5. HP 15-d076nr Charge Port Replacement, Wireless Card: step 5, image 1 of 1
    • Re-orient the laptop, so that the back of the laptop faces away from you.
    Ask FixBot
  6. HP 15-d076nr Charge Port Replacement: step 6, image 1 of 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
    Ask FixBot
  7. HP 15-d076nr Charge Port Replacement: step 7, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 7, image 2 of 2
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
    Ask FixBot
  8. HP 15-d076nr Charge Port Replacement: step 8, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 8, image 2 of 2
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
    Ask FixBot
  9. HP 15-d076nr Charge Port Replacement: step 9, image 1 of 3 HP 15-d076nr Charge Port Replacement: step 9, image 2 of 3 HP 15-d076nr Charge Port Replacement: step 9, image 3 of 3
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
    Ask FixBot
  10. HP 15-d076nr Charge Port Replacement: step 10, image 1 of 1
    • Slide the wireless card to the left to remove it from the socket.
    Ask FixBot
  11. HP 15-d076nr Charge Port Replacement, Motherboard: step 11, image 1 of 1
    • Locate the RAM in the exposed area.
    Ask FixBot
  12. HP 15-d076nr Charge Port Replacement: step 12, image 1 of 3 HP 15-d076nr Charge Port Replacement: step 12, image 2 of 3 HP 15-d076nr Charge Port Replacement: step 12, image 3 of 3
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
    Ask FixBot
  13. HP 15-d076nr Charge Port Replacement: step 13, image 1 of 1
    • Remove the RAM.
    Ask FixBot
  14. HP 15-d076nr Charge Port Replacement: step 14, image 1 of 3 HP 15-d076nr Charge Port Replacement: step 14, image 2 of 3 HP 15-d076nr Charge Port Replacement: step 14, image 3 of 3
    • Locate the ribbon cables.
    • Pry up the black tabs on the connectors and disconnect both of the ribbon cables.
    Ask FixBot
  15. HP 15-d076nr Charge Port Replacement: step 15, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 15, image 2 of 2
    • Locate the DVD drive screw.
    • Remove the Phillips PM2.5×6.5 screw using a Phillips #0 screwdriver.
    • Continue using a Phillips #0 screwdriver for the rest of this guide, and subsequent guides.
    • Take the screw and place it in a container so as to not lose it.
    Ask FixBot
  16. HP 15-d076nr Charge Port Replacement: step 16, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 16, image 2 of 2
    • Push down the tab that is located by the DVD drive screw.
    • Take the DVD drive in one hand, and using the plastic spludger, push the tab down, and out.
    Ask FixBot
  17. HP 15-d076nr Charge Port Replacement: step 17, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 17, image 2 of 2
    • Remove the fourteen Phillips PM2.5×6.0 screws, and place them in a separate container.
    Ask FixBot
  18. HP 15-d076nr Charge Port Replacement: step 18, image 1 of 3 HP 15-d076nr Charge Port Replacement: step 18, image 2 of 3 HP 15-d076nr Charge Port Replacement: step 18, image 3 of 3
    • Flip the laptop over, and open it as if you were using it.
    • Gently, remove the laptop cover/keyboard from the laptop using the plastic spudger.
    • When you remove the cover/keyboard, the laptop will become top heavy.
    Ask FixBot
  19. HP 15-d076nr Charge Port Replacement: step 19, image 1 of 1
    • Disconnect the monitor cable, using the plastic spudger, and pry it upwards.
    • Pull the cable from its routing until it is free.
    Ask FixBot
  20. HP 15-d076nr Charge Port Replacement: step 20, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 20, image 2 of 2
    • Lift the black tabs, and disconnect the three ribbon cables.
    • Disconnect the red-black-white speaker cable located in the lower left corner.
    Ask FixBot
  21. HP 15-d076nr Charge Port Replacement: step 21, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 21, image 2 of 2
    • Remove the three Phillips PM2.5×4.0 screws on the card reader in the bottom left corner.
    • Place the screws in a separate container.
    • Remove the card reader.
    Ask FixBot
  22. HP 15-d076nr Charge Port Replacement: step 22, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 22, image 2 of 2
    • Remove the five Phillips PM2.5×5.0 screws on the motherboard.
    Ask FixBot
  23. HP 15-d076nr Charge Port Replacement: step 23, image 1 of 1
    • Remove the Phillips PM2.5×5.0 screw located on the fan, in the upper right corner.
    Ask FixBot
  24. HP 15-d076nr Charge Port Replacement: step 24, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 24, image 2 of 2
    • Carefully lift up the motherboard.
    • Do not completely remove the motherboard. Simply lift it. There is a black cable on the bottom of the motherboard that is anchoring it.
    Ask FixBot
  25. HP 15-d076nr Charge Port Replacement: step 25, image 1 of 1
    • Locate the cable on the underside of the motherboard, in its lower right corner.
    • Carefully grip the cable, and pull downward to remove it.
    Ask FixBot
  26. HP 15-d076nr Charge Port Replacement: step 26, image 1 of 1
    • Flip the motherboard over.
    Ask FixBot
  27. HP 15-d076nr Charge Port Replacement: step 27, image 1 of 1
    • Locate the charge port cable connection point on the motherboard.
    • Grab the charge port cable's connector, and wiggle it to remove it.
    • Set the board off to the side.
    Ask FixBot
  28. HP 15-d076nr Charge Port Replacement, Charge Port: step 28, image 1 of 3 HP 15-d076nr Charge Port Replacement, Charge Port: step 28, image 2 of 3 HP 15-d076nr Charge Port Replacement, Charge Port: step 28, image 3 of 3
    • Unscrew the two screws located in the upper left corner, and the three screws in the upper right, on the metal hinges of the monitor.
    • This step will disconnect the monitor. Make sure the monitor does not fall or become damaged.
    Ask FixBot
  29. HP 15-d076nr Charge Port Replacement: step 29, image 1 of 1
    • Carefully lay the monitor down flat.
    Ask FixBot
  30. HP 15-d076nr Charge Port Replacement: step 30, image 1 of 2 HP 15-d076nr Charge Port Replacement: step 30, image 2 of 2
    • Pull the charge port away from the body of the laptop.
    Ask FixBot
Amy Weed
577 Reputation
5 Guides authored
2 Guide Comments
Thanks for a detailed insight on charging port replacement. I was going for a charging port replacement for my HP Pavillion laptop because it was not charging when plugged in. Then I come across this guide, and I removed the battery to reset the power controller module and updated the Microsoft ACPI Compliant Control Method Battery driver, and it started charging.
Your guide is really helpful and step-by-step. Thank you once again.
Jhon Ahemad - Reply Share
Thank you detailing charging port replacement. I really learn many thing from your blog helping. From your guide i replace my laptop battery step by step.I remove my laptop battery clean pots and update driver or its start charging.
relaxingmusic2162 - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 1,116
