HP 15-bs168cl Screen Replacement
    1. HP 15-bs168cl Screen Replacement, Screen: step 1, image 1 of 2 HP 15-bs168cl Screen Replacement, Screen: step 1, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Open the device so the screen is facing out.
      • Slide a thin plastic card into the space between the screen and the bezel. Slide the card around the entire screen to detach the case.
      • There is glue at the bottom so extra force may be needed to remove it.
      Ask FixBot
    2. HP 15-bs168cl Screen Replacement: step 2, image 1 of 3 HP 15-bs168cl Screen Replacement: step 2, image 2 of 3 HP 15-bs168cl Screen Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to unscrew the four screws at the top corners and the two screws at the bottom corners.
      Ask FixBot
    3. HP 15-bs168cl Screen Replacement: step 3, image 1 of 1
      • Remove the screen from the frame.
      • Remove the tape on the cable connected to the screen. Unplug the cable.
      Ask FixBot
2 other people completed this guide.
Ian Gascon
822 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 57
All Time: 1,398
