HP 15-bs168cl Hard Drive Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
56
All Time:
2,048
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Here is a step by step way to remove and replace your hard drive for the HP 15-bs168cl. Signs of hard drive failure include experiencing frequent but irregular crashes, files and folders disappearing, really long wait times to access folders and files, or your hard drive is noisy and begins to click. You can troubleshoot your hard drive by following the steps here before trying to replace it.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. HP 15-bs168cl Hard Drive Replacement, Battery: step 1, image 1 of 2 HP 15-bs168cl Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Unplug your laptop from its power adapter.
      • Turn the laptop over.
      Ask FixBot
    2. HP 15-bs168cl Hard Drive Replacement: step 2, image 1 of 2 HP 15-bs168cl Hard Drive Replacement: step 2, image 2 of 2
      • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
      Ask FixBot
    3. HP 15-bs168cl Hard Drive Replacement: step 3, image 1 of 2 HP 15-bs168cl Hard Drive Replacement: step 3, image 2 of 2
      • Slide the Battery release slider towards the battery while pulling the battery out.
      Ask FixBot
    1. HP 15-bs168cl Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 HP 15-bs168cl Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
      Ask FixBot
    2. HP 15-bs168cl Hard Drive Replacement: step 5, image 1 of 2 HP 15-bs168cl Hard Drive Replacement: step 5, image 2 of 2
      • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
      • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
      Ask FixBot
    3. HP 15-bs168cl Hard Drive Replacement: step 6, image 1 of 1
      • Remove the DVD drive by carefully sliding it out.
      Ask FixBot
    4. HP 15-bs168cl Hard Drive Replacement: step 7, image 1 of 3 HP 15-bs168cl Hard Drive Replacement: step 7, image 2 of 3 HP 15-bs168cl Hard Drive Replacement: step 7, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Flip the laptop over and open the screen.
      • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
      • Flip the computer back over and remove the bottom plastic shell.
      Ask FixBot
    5. HP 15-bs168cl Hard Drive Replacement: step 8, image 1 of 3 HP 15-bs168cl Hard Drive Replacement: step 8, image 2 of 3 HP 15-bs168cl Hard Drive Replacement: step 8, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 3.4 mm screws on the sides.
      • Use a Phillips #0 screwdriver to remove the one 3.3 mm screw at the bottom of the bracket.
      Ask FixBot
    6. HP 15-bs168cl Hard Drive Replacement: step 9, image 1 of 2 HP 15-bs168cl Hard Drive Replacement: step 9, image 2 of 2
      • Remove the metal bracket holding the hard drive in place.
      • Carefully lift up the hard drive and slide it out of its connector.
      Ask FixBot
6 other people completed this guide.
Ian Gascon
822 Reputation
4 Guides authored
1 Guide Comment
Thanks, I would have missed the screws under the rubber feet!
Kenneth Dalton - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 56
All Time: 2,048
