HP 15-bs168cl Fan Replacement
    1. HP 15-bs168cl Fan Replacement, Battery: step 1, image 1 of 2 HP 15-bs168cl Fan Replacement, Battery: step 1, image 2 of 2
      • Unplug your laptop from its power adapter.
      • Turn the laptop over.
      Ask FixBot
    2. HP 15-bs168cl Fan Replacement: step 2, image 1 of 2 HP 15-bs168cl Fan Replacement: step 2, image 2 of 2
      • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
      Ask FixBot
    3. HP 15-bs168cl Fan Replacement: step 3, image 1 of 2 HP 15-bs168cl Fan Replacement: step 3, image 2 of 2
      • Slide the Battery release slider towards the battery while pulling the battery out.
      Ask FixBot
    1. HP 15-bs168cl Fan Replacement, Fan: step 4, image 1 of 2 HP 15-bs168cl Fan Replacement, Fan: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
      Ask FixBot
    2. HP 15-bs168cl Fan Replacement: step 5, image 1 of 2 HP 15-bs168cl Fan Replacement: step 5, image 2 of 2
      • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
      • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
      Ask FixBot
    3. HP 15-bs168cl Fan Replacement: step 6, image 1 of 1
      • Remove the DVD drive by carefully sliding it out.
      Ask FixBot
    4. HP 15-bs168cl Fan Replacement: step 7, image 1 of 3 HP 15-bs168cl Fan Replacement: step 7, image 2 of 3 HP 15-bs168cl Fan Replacement: step 7, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Flip the laptop over and open the screen.
      • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
      • Flip the computer back over and remove the bottom plastic shell.
      Ask FixBot
    5. HP 15-bs168cl Fan Replacement: step 8, image 1 of 2 HP 15-bs168cl Fan Replacement: step 8, image 2 of 2
      • Using a Phillips #1 screwdriver remove the screw from the Wi-fi card.
      • Remove the card.
      Ask FixBot
    6. HP 15-bs168cl Fan Replacement: step 9, image 1 of 2 HP 15-bs168cl Fan Replacement: step 9, image 2 of 2
      • Carefully unplug the LCD connector using a plastic spudger.
      Ask FixBot
    7. HP 15-bs168cl Fan Replacement: step 10, image 1 of 2 HP 15-bs168cl Fan Replacement: step 10, image 2 of 2
      • Unplug the power connector.
      Ask FixBot
    8. HP 15-bs168cl Fan Replacement: step 11, image 1 of 3 HP 15-bs168cl Fan Replacement: step 11, image 2 of 3 HP 15-bs168cl Fan Replacement: step 11, image 3 of 3
      • Pull all three cables to the side to reveal the 6.7 mm screw attached to the fan.
      • Remove the screw with a Phillips #0 screwdriver.
      • Unplug the fan connector.
      • Pull out the fan carefully leaving the heatsink in place.
      Ask FixBot
Christian Puga
361 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 58
All Time: 1,140
