Up to 20% off select tools
HP 15-bs051od RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
58
All Time:
684
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a guide for replacing the RAM for the HP 15-bs051od. Possible reasons to replace RAM may be the computer is freezing, randomly crashing, or computer is displaying the Blue Screen of Death.
Note: Our model does not include a battery. Before performing any repair ensure the battery has been removed and the computer is not connected to a power source. It is also important to ground yourself by touching metal to discharge excess electricity before beginning the repair.
    1. HP 15-bs051od RAM Replacement, RAM: step 1, image 1 of 1
      • Start with the laptop face down.
      • Remove the eight 6 mm Phillips head screws securing the lower case.
      Ask FixBot
    2. HP 15-bs051od RAM Replacement: step 2, image 1 of 2 HP 15-bs051od RAM Replacement: step 2, image 2 of 2
      • Use the opening tool to pry the lower case away from the body of the laptop.
      • Remove the lower case.
      Ask FixBot
    3. HP 15-bs051od RAM Replacement: step 3, image 1 of 3 HP 15-bs051od RAM Replacement: step 3, image 2 of 3 HP 15-bs051od RAM Replacement: step 3, image 3 of 3
      • Pull the RAM-retaining arms away from the RAM chip.
      • The RAM chip should slightly "pop" up from it's socket.
      Ask FixBot
    4. HP 15-bs051od RAM Replacement: step 4, image 1 of 2 HP 15-bs051od RAM Replacement: step 4, image 2 of 2
      • Pull the RAM chip out of its socket.
      • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
      • Repeat this process for the second RAM chip.
      Ask FixBot
Author
with
Jessica Walia
607 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 58
All Time: 684
