HP 15-bs051od Motherboard Replacement
    1. HP 15-bs051od Motherboard Replacement, RAM: step 1, image 1 of 1
      • Start with the laptop face down.
      • Remove the eight 6 mm Phillips head screws securing the lower case.
      Ask FixBot
    2. HP 15-bs051od Motherboard Replacement: step 2, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 2, image 2 of 2
      • Use the opening tool to pry the lower case away from the body of the laptop.
      • Remove the lower case.
      Ask FixBot
    3. HP 15-bs051od Motherboard Replacement: step 3, image 1 of 3 HP 15-bs051od Motherboard Replacement: step 3, image 2 of 3 HP 15-bs051od Motherboard Replacement: step 3, image 3 of 3
      • Pull the RAM-retaining arms away from the RAM chip.
      • The RAM chip should slightly "pop" up from it's socket.
      Ask FixBot
    4. HP 15-bs051od Motherboard Replacement: step 4, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 4, image 2 of 2
      • Pull the RAM chip out of its socket.
      • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
      • Repeat this process for the second RAM chip.
      Ask FixBot
    1. HP 15-bs051od Motherboard Replacement, Motherboard: step 5, image 1 of 3 HP 15-bs051od Motherboard Replacement, Motherboard: step 5, image 2 of 3 HP 15-bs051od Motherboard Replacement, Motherboard: step 5, image 3 of 3
      • Remove the four (4 mm) Phillips screws on the heatsink.
      • Remove the exhaust by carefully lifting it up.
      Ask FixBot
    2. HP 15-bs051od Motherboard Replacement: step 6, image 1 of 1
      • Disconnect the connecting cable of the fan and remove the fan.
      Ask FixBot
    3. HP 15-bs051od Motherboard Replacement: step 7, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 7, image 2 of 2
      • Pull the red, white, black, and blue cable directly out of its port.
      Ask FixBot
    4. HP 15-bs051od Motherboard Replacement: step 8, image 1 of 1
      • Slide the left speaker out.
      Ask FixBot
    5. HP 15-bs051od Motherboard Replacement: step 9, image 1 of 1
      • Pull the black and red cable connecting both speakers out of its secure fastening.
      Ask FixBot
    6. HP 15-bs051od Motherboard Replacement: step 10, image 1 of 1
      • Pull the right speaker out by sliding from left to right.
      Ask FixBot
    7. HP 15-bs051od Motherboard Replacement: step 11, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 11, image 2 of 2
      • Locate the motherboard.
      • The motherboard is the biggest blue-colored surface located inside the computer.
      • Locate the six ribbon cables.
      Ask FixBot
    8. HP 15-bs051od Motherboard Replacement: step 12, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 12, image 2 of 2
      • Flip up the ZIF lock bars that keep the six ribbon cables in place.
      • Slide the rest of the ribbon cables out of their fastenings.
      Ask FixBot
    9. HP 15-bs051od Motherboard Replacement: step 13, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 13, image 2 of 2
      • Remove the four (4 mm) Phillips screws securing the motherboard.
      Ask FixBot
    10. HP 15-bs051od Motherboard Replacement: step 14, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 14, image 2 of 2
      • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
      • Slide the Wi-Fi card out of its port.
      Ask FixBot
    11. HP 15-bs051od Motherboard Replacement: step 15, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 15, image 2 of 2
      • Unfasten the connecting cable.
      Ask FixBot
    12. HP 15-bs051od Motherboard Replacement: step 16, image 1 of 2 HP 15-bs051od Motherboard Replacement: step 16, image 2 of 2
      • Remove the display cable.
      Ask FixBot
    13. HP 15-bs051od Motherboard Replacement: step 17, image 1 of 1
      • Lift up the motherboard.
      Ask FixBot
Jessica Walia
589 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 735
