HP 15-ba0709dx Hard Drive Replacement
Views: 6.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
102
All Time:
6,190
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Follow this guide to replace the hard drive on HP 15-ba0709dx laptop. This repair may be needed if your computer is showing the symptoms such as freezing, slowing down, or corrupting files.
Tools
    1. HP 15-ba0709dx Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch on the left and right side until the battery is detached from its slot.
      • A noticeable pop will be heard when the battery is fully released.
      Ask FixBot
    2. HP 15-ba0709dx Hard Drive Replacement: step 2, image 1 of 1
      • Pull the battery out of its slot.
      • Be careful not to damage any of the connectors in the process.
      Ask FixBot
    1. HP 15-ba0709dx Hard Drive Replacement, Back Cover: step 3, image 1 of 1
      • Place the laptop on a clean, flat surface with the bottom side facing up.
      Ask FixBot
    2. HP 15-ba0709dx Hard Drive Replacement: step 4, image 1 of 1
      • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
      • Note: Make sure to keep track of the screws once they have been removed.
      Ask FixBot
    3. HP 15-ba0709dx Hard Drive Replacement: step 5, image 1 of 1
      • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
      • Note:Place these newly removed screws with the ones removed in Step 2.
      Ask FixBot
    4. HP 15-ba0709dx Hard Drive Replacement: step 6, image 1 of 2 HP 15-ba0709dx Hard Drive Replacement: step 6, image 2 of 2
      • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
      • Removing the friction pads will reveal two more anchoring screws.
      • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
      Ask FixBot
    5. HP 15-ba0709dx Hard Drive Replacement: step 7, image 1 of 1
      • Remove disc reader.
      • Note: If all screws are removed it should slide out easily.
      Ask FixBot
    6. HP 15-ba0709dx Hard Drive Replacement: step 8, image 1 of 2 HP 15-ba0709dx Hard Drive Replacement: step 8, image 2 of 2
      • Use a plastic prod to pry the back cover off the laptop.
      • Be careful not to damage the laptop while prying.
      Ask FixBot
    1. HP 15-ba0709dx Hard Drive Replacement, Hard Drive: step 9, image 1 of 1
      • Locate the square, blue hard drive
      • Unscrew the two screws holding it in place using a Philips screwdriver head, PH1. The screws will be 8 mm long with a 4 mm width head.
      Ask FixBot
    2. HP 15-ba0709dx Hard Drive Replacement: step 10, image 1 of 1
      • Lift the hard drive out of its slot after screws are removed.
      Ask FixBot
    3. HP 15-ba0709dx Hard Drive Replacement: step 11, image 1 of 1
      • Squeeze to release and pull adapter cable from the side of hard drive.
      • Be careful not to damage the adapter.
      Ask FixBot
5 other people completed this guide.
Lydia Brown
369 Reputation
2 Guides authored
1 Guide Comment
Many thanks for this! The adhesive pads were foiling my attempts, and I was afraid of breaking things. Perfect instructions, I accomplished my goal :)
Diana K - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 102
All Time: 6,190
