HP 15-ay114cy Screen Replacement
    1. HP 15-ay114cy Screen Replacement, Orient the Laptop: step 1, image 1 of 1
      • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
      • Ensure the laptop is powered off before moving forward.
      Ask FixBot
    2. HP 15-ay114cy Screen Replacement, Push out the Battery: step 2, image 1 of 2 HP 15-ay114cy Screen Replacement, Push out the Battery: step 2, image 2 of 2
      • Place your index fingers on each of the two battery holder clips.
      • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
      Ask FixBot
    3. HP 15-ay114cy Screen Replacement, Remove the Battery: step 3, image 1 of 2 HP 15-ay114cy Screen Replacement, Remove the Battery: step 3, image 2 of 2
      • After the battery clips are pushed in, use either hand to grab hold of the battery.
      • Gently push up to remove the battery.
      Ask FixBot
    1. HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: step 4, image 1 of 2 HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: step 4, image 2 of 2
      • Insert the flat end of the plastic opening tool between the screen and plastic frame.
      • Use the plastic opening tool to carefully pry the plastic frame off of the screen, starting in the middle and moving towards the corners.
      Ask FixBot
    2. HP 15-ay114cy Screen Replacement, Remove the Screen: step 5, image 1 of 3 HP 15-ay114cy Screen Replacement, Remove the Screen: step 5, image 2 of 3 HP 15-ay114cy Screen Replacement, Remove the Screen: step 5, image 3 of 3
      • Use the #00 Phillips-head screwdriver to remove the four 3 mm screws in each corner and carefully detach the screen and lay it onto the keyboard.
      Ask FixBot
    3. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: step 6, image 1 of 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: step 6, image 2 of 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: step 6, image 3 of 3
      • Use your thumb and pointer finger to cautiously remove the display connector from the metal frame.
      Ask FixBot
Bradley Evans
622 Reputation
5 Guides authored
S20S3G#1 Member of S20S3G#1
Local Repair Groups
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 59
All Time: 705
