HP 15-ay114cy Motherboard Replacement
    1. HP 15-ay114cy Motherboard Replacement, Orient the Laptop: step 1, image 1 of 1
      • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
      • Ensure the laptop is powered off before moving forward.
      Ask FixBot
    2. HP 15-ay114cy Motherboard Replacement, Push out the Battery: step 2, image 1 of 2 HP 15-ay114cy Motherboard Replacement, Push out the Battery: step 2, image 2 of 2
      • Place your index fingers on each of the two battery holder clips.
      • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
      Ask FixBot
    3. HP 15-ay114cy Motherboard Replacement, Remove the Battery: step 3, image 1 of 2 HP 15-ay114cy Motherboard Replacement, Remove the Battery: step 3, image 2 of 2
      • After the battery clips are pushed in, use either hand to grab hold of the battery.
      • Gently push up to remove the battery.
      Ask FixBot
    1. HP 15-ay114cy Motherboard Replacement, Unscrew the Back Cover: step 4, image 1 of 2 HP 15-ay114cy Motherboard Replacement, Unscrew the Back Cover: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the twelve 8 mm Phillips screws that are holding down the bottom cover of the laptop.
      Ask FixBot
    2. HP 15-ay114cy Motherboard Replacement, Remove the Disk Drive: step 5, image 1 of 2 HP 15-ay114cy Motherboard Replacement, Remove the Disk Drive: step 5, image 2 of 2
      • Grab a hold of the disk drive and carefully pull it away from the computer.
      • Continue to slide the disk drive out of the laptop until fully removed.
      • Due to the removal of the battery, no power is available to open the disk drive through the use of the eject button.
      • Make sure to pull out the disk drive at a 90 degree angle as demonstrated. Do not attempt to wiggle the drive out of the laptop.
      • There will be resistance when removing the drive. Mishandling may cause broken wires, which could make your disk drive inoperative.
      Ask FixBot
    3. HP 15-ay114cy Motherboard Replacement, Remove the Back Cover: step 6, image 1 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Back Cover: step 6, image 2 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Back Cover: step 6, image 3 of 3
      • Place a plastic opening tool in-between the upper and lower pieces of the bottom cover.
      • Using your hands and the plastic opening tool, gently separate the cover from the frame.
      • Slowly remove the bottom cover from the base of the laptop.
      • Using metal pry tools can damage your device.
      Ask FixBot
    4. HP 15-ay114cy Motherboard Replacement, Remove the Fan Screws: step 7, image 1 of 2 HP 15-ay114cy Motherboard Replacement, Remove the Fan Screws: step 7, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two 8 mm Phillips-head screws that attach the fan to the base.
      Ask FixBot
    5. HP 15-ay114cy Motherboard Replacement, Remove the Fan Wire: step 8, image 1 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Fan Wire: step 8, image 2 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Fan Wire: step 8, image 3 of 3
      • Using your index finger and thumb, carefully grab the wire that connects the fan to the motherboard.
      • Using a bit of force, remove the cable from the connector on the motherboard.
      Ask FixBot
    6. HP 15-ay114cy Motherboard Replacement, Remove the Fan: step 9, image 1 of 2 HP 15-ay114cy Motherboard Replacement, Remove the Fan: step 9, image 2 of 2
      • Using your hand, grab one of the fan corners and pull up.
      • Carefully remove the entire fan from the base of the laptop.
      Ask FixBot
    1. HP 15-ay114cy Motherboard Replacement, Remove the Heatsink: step 10, image 1 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Heatsink: step 10, image 2 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Heatsink: step 10, image 3 of 3
      • Using the Phillips #0 screwdriver, unscrew the four 2 mm Phillips-head screws that secure the heatsink to the laptop base.
      • Grasp one end of the heatsink and then carefully lift up to remove it from the laptop base.
      Ask FixBot
    2. HP 15-ay114cy Motherboard Replacement, Remove the Speaker Wire Connection: step 11, image 1 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Speaker Wire Connection: step 11, image 2 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Speaker Wire Connection: step 11, image 3 of 3
      • Using your index finger and thumb, gently grasp the speaker cable and pull it from the connector.
      • Move along the speaker wire and ensure that none of the wiring is caught on other components or mounting tabs.
      • Remove the speakers.
      Ask FixBot
    3. HP 15-ay114cy Motherboard Replacement, Remove the Wired Connections: step 12, image 1 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Wired Connections: step 12, image 2 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Wired Connections: step 12, image 3 of 3
      • Place your index finger on the plastic ridge of each of the seven ZIF connectors connected to the motherboard.
      • Using your index finger, flip up the black tabs on each of the connectors to release the cable.
      • Gently pull each the wired connections from the motherboard.
      Ask FixBot
    4. HP 15-ay114cy Motherboard Replacement, Remove the Screws from the Base: step 13, image 1 of 2 HP 15-ay114cy Motherboard Replacement, Remove the Screws from the Base: step 13, image 2 of 2
      • Using a Phillips #0 screwdriver, unscrew the twelve 2 mm Phillips-head screws that secure the motherboard to the laptop base.
      Ask FixBot
    5. HP 15-ay114cy Motherboard Replacement, Remove the Wireless Card: step 14, image 1 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Wireless Card: step 14, image 2 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Wireless Card: step 14, image 3 of 3
      • Use your index finger and thumb to gently grasp the green wireless card, then pull the card horizontally out and away from the motherboard.
      Ask FixBot
    6. HP 15-ay114cy Motherboard Replacement, Remove the Audio/USB Board: step 15, image 1 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Audio/USB Board: step 15, image 2 of 3 HP 15-ay114cy Motherboard Replacement, Remove the Audio/USB Board: step 15, image 3 of 3
      • Use your index finger and thumb to gently grasp the display connector and remove it from the motherboard.
      • Carefully grasp an end of the motherboard and gradually lift it up and away from the laptop.
      Ask FixBot
Bradley Evans
622 Reputation
5 Guides authored
S20S3G#1 Member of S20S3G#1
Local Repair Groups
4 Members
66 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 922
