HP 15-ay114cy Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
64
All Time:
753
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your HP 15-ay114cy (also known as the HP Notebook 15) does not hold a charge, you most likely have a faulty or dead battery that will need to be replaced.
A properly working battery would experience a long battery life, in addition to being able to power on without any issues. However, since the battery is a consumable component of this device, over time it can experience wear after several charging cycles.
Before replacing the device battery, relate back to this troubleshooting page for further information about what is causing your symptoms. Ensure that all external devices are unplugged from your USB or Audio ports. It is also important to unplug the device from any charging cables and to turn off the device before following the replacement guide.
No tools or special skills will be required to remove and replace the device battery.
    1. HP 15-ay114cy Battery Replacement, Orient the Laptop: step 1, image 1 of 1
      • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
      • Ensure the laptop is powered off before moving forward.
      Ask FixBot
    2. HP 15-ay114cy Battery Replacement, Push out the Battery: step 2, image 1 of 2 HP 15-ay114cy Battery Replacement, Push out the Battery: step 2, image 2 of 2
      • Place your index fingers on each of the two battery holder clips.
      • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
      Ask FixBot
    3. HP 15-ay114cy Battery Replacement, Remove the Battery: step 3, image 1 of 2 HP 15-ay114cy Battery Replacement, Remove the Battery: step 3, image 2 of 2
      • After the battery clips are pushed in, use either hand to grab hold of the battery.
      • Gently push up to remove the battery.
      Ask FixBot
Michael Falanga
362 Reputation
1 Guide authored
S20S3G#1 Member of S20S3G#1
Local Repair Groups
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 64
All Time: 753
