HP 15-ay103dx Motherboard Replacement
    1. HP 15-ay103dx Motherboard  Replacement, Battery: step 1, image 1 of 1
      • Slide the two battery lock latches on the back of the device to the “unlock” position.
      Ask FixBot
    2. HP 15-ay103dx Motherboard  Replacement: step 2, image 1 of 1
      • Lift the battery upward to remove it from the device.
      Ask FixBot
    1. HP 15-ay103dx Motherboard  Replacement, Back Panel: step 3, image 1 of 1
      • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
      • There should be 10 in total, be sure to keep them together!
      Ask FixBot
    2. HP 15-ay103dx Motherboard  Replacement: step 4, image 1 of 1
      • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
      Ask FixBot
    3. HP 15-ay103dx Motherboard  Replacement: step 5, image 1 of 2 HP 15-ay103dx Motherboard  Replacement: step 5, image 2 of 2
      • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
      • Place the adhesive side up as you will need to place them back after your replacement is complete.
      Ask FixBot
    4. HP 15-ay103dx Motherboard  Replacement: step 6, image 1 of 2 HP 15-ay103dx Motherboard  Replacement: step 6, image 2 of 2
      • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
      • Be sure to keep the screws together!
      Ask FixBot
    5. HP 15-ay103dx Motherboard  Replacement: step 7, image 1 of 1
      • Carefully remove the back panel from the device.
      • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
      Ask FixBot
    1. HP 15-ay103dx Motherboard  Replacement, Motherboard: step 8, image 1 of 3 HP 15-ay103dx Motherboard  Replacement, Motherboard: step 8, image 2 of 3 HP 15-ay103dx Motherboard  Replacement, Motherboard: step 8, image 3 of 3
      • Disconnect the wires around the motherboard securing it to the device.
      • To do this, flip the black "switches" securing the wires into place upwards.
      Ask FixBot
    2. HP 15-ay103dx Motherboard  Replacement: step 9, image 1 of 1
      • Remove the six 5/16 in. screws holding the motherboard onto the device using the P1 philips-head screwdriver.
      • Be sure to keep them together!
      Ask FixBot
    3. HP 15-ay103dx Motherboard  Replacement: step 10, image 1 of 3 HP 15-ay103dx Motherboard  Replacement: step 10, image 2 of 3 HP 15-ay103dx Motherboard  Replacement: step 10, image 3 of 3
      • Disconnect the wire securing the whole motherboard located at the top to the motherboard.
      • This is possible with your fingers, but is easier to do using an iFixit opening tool.
      Ask FixBot
    4. HP 15-ay103dx Motherboard  Replacement: step 11, image 1 of 1
      • Carefully lift the motherboard to remove it from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 102
All Time: 2,157
