HP 15-ay103dx Display Screen Hinges Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
82
All Time:
1,225
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HP 15-ay103dx Display Screen Hinges Replacement, Battery: step 1, image 1 of 1
      • Slide the two battery lock latches on the back of the device to the “unlock” position.
      Ask FixBot
    2. HP 15-ay103dx Display Screen Hinges Replacement: step 2, image 1 of 1
      • Lift the battery upward to remove it from the device.
      Ask FixBot
    1. HP 15-ay103dx Display Screen Hinges Replacement, Back Panel: step 3, image 1 of 1
      • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
      • There should be 10 in total, be sure to keep them together!
      Ask FixBot
    2. HP 15-ay103dx Display Screen Hinges Replacement: step 4, image 1 of 1
      • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
      Ask FixBot
    3. HP 15-ay103dx Display Screen Hinges Replacement: step 5, image 1 of 2 HP 15-ay103dx Display Screen Hinges Replacement: step 5, image 2 of 2
      • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
      • Place the adhesive side up as you will need to place them back after your replacement is complete.
      Ask FixBot
    4. HP 15-ay103dx Display Screen Hinges Replacement: step 6, image 1 of 2 HP 15-ay103dx Display Screen Hinges Replacement: step 6, image 2 of 2
      • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
      • Be sure to keep the screws together!
      Ask FixBot
    5. HP 15-ay103dx Display Screen Hinges Replacement: step 7, image 1 of 1
      • Carefully remove the back panel from the device.
      • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
      Ask FixBot
    1. HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: step 8, image 1 of 2 HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: step 8, image 2 of 2
      • Use a spudger to carefully remove the border around the display screen.
      • As long as you are slow and delicate, the border will eventually come off.
      Ask FixBot
    2. HP 15-ay103dx Display Screen Hinges Replacement: step 9, image 1 of 2 HP 15-ay103dx Display Screen Hinges Replacement: step 9, image 2 of 2
      • Remove the two 5/16 screws in the top corners and the four in the bottom corners.
      Ask FixBot
    3. HP 15-ay103dx Display Screen Hinges Replacement: step 10, image 1 of 1
      • Carefully pull the screen from the hinges and lower it on to the table.
      • There will be wires running from the screen to the motherboard. You do not need to unplug these.
      • The hinges are made of malleable metal and are easily bent.
      Ask FixBot
    4. HP 15-ay103dx Display Screen Hinges Replacement: step 11, image 1 of 1
      • Remove the 5/16 screws securing the hinges to the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 82
All Time: 1,225
