Up to 20% off select tools
HP 15-ay103dx Back Panel Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
88
All Time:
2,098
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide entails removing screws and hinge covers to remove the back panel.
    1. HP 15-ay103dx Back Panel Replacement, Battery: step 1, image 1 of 1
      • Slide the two battery lock latches on the back of the device to the “unlock” position.
      Ask FixBot
    2. HP 15-ay103dx Back Panel Replacement: step 2, image 1 of 1
      • Lift the battery upward to remove it from the device.
      Ask FixBot
    1. HP 15-ay103dx Back Panel Replacement, Back Panel: step 3, image 1 of 1
      • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
      • There should be 10 in total, be sure to keep them together!
      Ask FixBot
    2. HP 15-ay103dx Back Panel Replacement: step 4, image 1 of 1
      • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
      Ask FixBot
    3. HP 15-ay103dx Back Panel Replacement: step 5, image 1 of 2 HP 15-ay103dx Back Panel Replacement: step 5, image 2 of 2
      • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
      • Place the adhesive side up as you will need to place them back after your replacement is complete.
      Ask FixBot
    4. HP 15-ay103dx Back Panel Replacement: step 6, image 1 of 2 HP 15-ay103dx Back Panel Replacement: step 6, image 2 of 2
      • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
      • Be sure to keep the screws together!
      Ask FixBot
    5. HP 15-ay103dx Back Panel Replacement: step 7, image 1 of 1
      • Carefully remove the back panel from the device.
      • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
      Ask FixBot
2 other people completed this guide.
Author
with
Morgan Churchill
278 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 88
All Time: 2,098
