Up to 20% off select tools
HP 15-ay091ms RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
57
All Time:
497
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This device guide page will help users remove and replace the hardware RAM of their HP 15-ay091ms device. This can be a fix to users who are experiencing an unresponsive screen on their device or other poor system functioning. This guide will help users remove the hardware RAM and replace it with a new one.
    1. HP 15-ay091ms RAM Replacement, Battery: step 1, image 1 of 2 HP 15-ay091ms RAM Replacement, Battery: step 1, image 2 of 2
      • Ensure the device is powered off and is disconnected from any AC power supply.
      • Push the latches on either side of the battery down and outward.
      • This unlatches the battery allowing for easy removal.
      • Remove the battery.
      Ask FixBot
    1. HP 15-ay091ms RAM Replacement, Back Panel: step 2, image 1 of 3 HP 15-ay091ms RAM Replacement, Back Panel: step 2, image 2 of 3 HP 15-ay091ms RAM Replacement, Back Panel: step 2, image 3 of 3
      • Remove the screws from the bottom panel using a JIS #0 screwdriver.
      • Use the iFixit opening pick to lift the back cover from the device.
      • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
      Ask FixBot
    1. HP 15-ay091ms RAM Replacement, RAM: step 3, image 1 of 3 HP 15-ay091ms RAM Replacement, RAM: step 3, image 2 of 3 HP 15-ay091ms RAM Replacement, RAM: step 3, image 3 of 3
      • Pull the metal brackets holding the RAM in place away from each other.
      • After you hold the brackets apart, the RAM will pop up.
      • Remove the RAM.
      Ask FixBot
Author
with
Gabriel
145 Reputation
2 Guides authored
Gateway, Team A-1, Gonzalez Fall 2023 Member of Gateway, Team A-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23SAG1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 57
All Time: 497
