HP 15-ay078nr Screen Replacement
    1. HP 15-ay078nr Screen Replacement, Screen: step 1, image 1 of 1
      • Open the lid of the laptop.
      • Feel the top of the laptop screen to find a ridge separating the front and back of the screen bezel.
      • Using an opening pick tool, gently pry the front screen bezel apart from the rear to release the internal plastic retention clips.
      • You may see small bits of plastic come loose from the screen bezel. This is not an issue and will not hurt the reassembly process.
      Ask FixBot
    2. HP 15-ay078nr Screen Replacement: step 2, image 1 of 2 HP 15-ay078nr Screen Replacement: step 2, image 2 of 2
      • Remove the four 3.2 mm screws from the screen using a Phillips #2 screwdriver.
      Ask FixBot
    3. HP 15-ay078nr Screen Replacement: step 3, image 1 of 3 HP 15-ay078nr Screen Replacement: step 3, image 2 of 3 HP 15-ay078nr Screen Replacement: step 3, image 3 of 3
      • Gently lay the screen against the keyboard.
      • Disconnect the display cable from the rest of the laptop.
      Ask FixBot
Power on your device to see the new screen. If the backlight is flickering, the LCD cable may have not been pushed in completely. Ensure it is fully connected.
Liberty DeAngelo
97 Reputation
1 Guide authored
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 56
All Time: 506
