HP 15-ay078nr Battery Replacement
    1. HP 15-ay078nr Battery Replacement, Battery: step 1, image 1 of 1
      • Orient the laptop so that the underside is facing up.
      • Rotate the device so that the CD slot is in the upper left corner.
      Ask FixBot
    2. HP 15-ay078nr Battery Replacement: step 2, image 1 of 2 HP 15-ay078nr Battery Replacement: step 2, image 2 of 2
      • Put your fingers on the battery latch.
      Ask FixBot
    3. HP 15-ay078nr Battery Replacement: step 3, image 1 of 2 HP 15-ay078nr Battery Replacement: step 3, image 2 of 2
      • Using your fingers, push each battery latch simultaneously towards the middle.
      • This releases the battery.
      • Remove the battery from the laptop.
      Ask FixBot
After installing the replacement battery, connect the device to a power source. The battery will not have a prior charge.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cameron Duffy
327 Reputation
3 Guides authored
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 57
All Time: 540
