HP 15-ay078nr Back Panel Replacement
    1. HP 15-ay078nr Back Panel Replacement, Battery: step 1, image 1 of 1
      • Orient the laptop so that the underside is facing up.
      • Rotate the device so that the CD slot is in the upper left corner.
      Ask FixBot
    2. HP 15-ay078nr Back Panel Replacement: step 2, image 1 of 2 HP 15-ay078nr Back Panel Replacement: step 2, image 2 of 2
      • Put your fingers on the battery latch.
      Ask FixBot
    3. HP 15-ay078nr Back Panel Replacement: step 3, image 1 of 2 HP 15-ay078nr Back Panel Replacement: step 3, image 2 of 2
      • Using your fingers, push each battery latch simultaneously towards the middle.
      • This releases the battery.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP 15-ay078nr Back Panel Replacement, Back Panel: step 4, image 1 of 2 HP 15-ay078nr Back Panel Replacement, Back Panel: step 4, image 2 of 2
      • Pull off the two rubber feet on the underside of the device.
      • Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
      Ask FixBot
    2. HP 15-ay078nr Back Panel Replacement: step 5, image 1 of 1
      • Slide an opening pick around the edges between the back panel and the rest of the device to release the plastic retention clips that hold the panel in place.
      Ask FixBot
    3. HP 15-ay078nr Back Panel Replacement: step 6, image 1 of 1
      • Lift up on the panel to remove it completely from the device.
      Ask FixBot
Bryce Getchell
315 Reputation
3 Guides authored
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 71
All Time: 534
