HP 15-ay052nr USB Port Replacement
    1. HP 15-ay052nr USB Port Replacement, Battery: step 1, image 1 of 1
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      Ask FixBot
    2. HP 15-ay052nr USB Port Replacement: step 2, image 1 of 1
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      Ask FixBot
    3. HP 15-ay052nr USB Port Replacement: step 3, image 1 of 1
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      Ask FixBot
    1. HP 15-ay052nr USB Port Replacement, Bottom Cover: step 4, image 1 of 1
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
      Ask FixBot
    2. HP 15-ay052nr USB Port Replacement: step 5, image 1 of 1
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
      Ask FixBot
    3. HP 15-ay052nr USB Port Replacement: step 6, image 1 of 1
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
      Ask FixBot
    4. HP 15-ay052nr USB Port Replacement: step 7, image 1 of 1
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
      Ask FixBot
    1. HP 15-ay052nr USB Port Replacement, USB Port: step 8, image 1 of 1
      • Remove the three 3mm JIS #0 screws from the hard drive.
      Ask FixBot
    2. HP 15-ay052nr USB Port Replacement: step 9, image 1 of 1
      • Unplug the hard drive and set aside.
      Ask FixBot
    3. HP 15-ay052nr USB Port Replacement: step 10, image 1 of 1
      • Disconnect the cable that is attached to the motherboard from the USB board.
      • The motherboard can be identified as the big blue board in the opposite side of the USB board we are replacing.
      Ask FixBot
    4. HP 15-ay052nr USB Port Replacement: step 11, image 1 of 1
      • Remove the single 3mm JIS #0 screw.
      • Once the screw is out, the USB board can be pulled out for replacement.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 63
All Time: 762
