HP 15-ay052nr Keyboard and Touchpad Replacement
    1. HP 15-ay052nr Keyboard and Touchpad Replacement, Battery: step 1, image 1 of 1
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      Ask FixBot
    2. HP 15-ay052nr Keyboard and Touchpad Replacement: step 2, image 1 of 1
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      Ask FixBot
    3. HP 15-ay052nr Keyboard and Touchpad Replacement: step 3, image 1 of 1
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      Ask FixBot
    1. HP 15-ay052nr Keyboard and Touchpad Replacement, Bottom Cover: step 4, image 1 of 1
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
      Ask FixBot
    2. HP 15-ay052nr Keyboard and Touchpad Replacement: step 5, image 1 of 1
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
      Ask FixBot
    3. HP 15-ay052nr Keyboard and Touchpad Replacement: step 6, image 1 of 1
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
      Ask FixBot
    4. HP 15-ay052nr Keyboard and Touchpad Replacement: step 7, image 1 of 1
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
      Ask FixBot
    1. HP 15-ay052nr Keyboard and Touchpad Replacement, Fan: step 8, image 1 of 1
      • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
      • The base is the side by the heatsink, which is made of copper.
      Ask FixBot
    2. HP 15-ay052nr Keyboard and Touchpad Replacement: step 9, image 1 of 1
      • Unplug the fan cable from the motherboard.
      • The fan can now be removed.
      Ask FixBot
    1. HP 15-ay052nr Keyboard and Touchpad Replacement, Motherboard: step 10, image 1 of 1
      • Remove the three 3 mm JIS #0 screws from the hard drive.
      Ask FixBot
    2. HP 15-ay052nr Keyboard and Touchpad Replacement: step 11, image 1 of 1
      • Unplug the hard drive from the motherboard.
      Ask FixBot
    3. HP 15-ay052nr Keyboard and Touchpad Replacement: step 12, image 1 of 1
      • Unplug display from the motherboard.
      • The connection is under a sealing sticker; peel up the sticker to unplug the connection.
      Ask FixBot
    4. HP 15-ay052nr Keyboard and Touchpad Replacement: step 13, image 1 of 1
      • Unplug the power port from the motherboard.
      Ask FixBot
    5. HP 15-ay052nr Keyboard and Touchpad Replacement: step 14, image 1 of 1
      • Unplug the display wire from the wireless adapter.
      Ask FixBot
    6. HP 15-ay052nr Keyboard and Touchpad Replacement: step 15, image 1 of 1
      • Remove the single screw from the wireless card and gently remove the drive.
      Ask FixBot
    7. HP 15-ay052nr Keyboard and Touchpad Replacement: step 16, image 1 of 1
      • Unplug the keyboard from the motherboard.
      Ask FixBot
    8. HP 15-ay052nr Keyboard and Touchpad Replacement: step 17, image 1 of 1
      • Unplug the optical drive connection from the motherboard.
      Ask FixBot
    9. HP 15-ay052nr Keyboard and Touchpad Replacement: step 18, image 1 of 1
      • Remove the memory chip from the motherboard by pushing the clips away from the chip.
      • The chip will pop out once the clips are pulled far enough apart.
      • This is to access the touch-pad wires.
      Ask FixBot
    10. HP 15-ay052nr Keyboard and Touchpad Replacement: step 19, image 1 of 1
      • Unplug both (2) wires for the touch-pad from the motherboard.
      Ask FixBot
    11. HP 15-ay052nr Keyboard and Touchpad Replacement: step 20, image 1 of 1
      • Unplug the speakers from the motherboard.
      Ask FixBot
    12. HP 15-ay052nr Keyboard and Touchpad Replacement: step 21, image 1 of 1
      • Unplug the power button from the motherboard.
      Ask FixBot
    13. HP 15-ay052nr Keyboard and Touchpad Replacement: step 22, image 1 of 1
      • Unscrew the four 3mm JIS #0 screws that secure the motherboard.
      • Once all the screws are removed, the motherboard can be removed by simply lifting it up.
      Ask FixBot
    1. HP 15-ay052nr Keyboard and Touchpad Replacement, Keyboard and Touchpad: step 23, image 1 of 1
      • Remove the two 3mm JIS #0 screws that secure the touchpad board.
      Ask FixBot
    2. HP 15-ay052nr Keyboard and Touchpad Replacement: step 24, image 1 of 2 HP 15-ay052nr Keyboard and Touchpad Replacement: step 24, image 2 of 2
      • Remove the display by unscrewing the four 3mm JIS #0 screws.
      • Remove one 2mm JIS #0 screw.
      Ask FixBot
    3. HP 15-ay052nr Keyboard and Touchpad Replacement: step 25, image 1 of 1
      • Lift the power port from its cradle.
      Ask FixBot
    4. HP 15-ay052nr Keyboard and Touchpad Replacement: step 26, image 1 of 1
      • Unscrew the one 3mm JIS #0 screw holding the power button board to the device.
      Ask FixBot
    5. HP 15-ay052nr Keyboard and Touchpad Replacement: step 27, image 1 of 2 HP 15-ay052nr Keyboard and Touchpad Replacement: step 27, image 2 of 2
      • Unscrew the two 3mm JIS #0 screws that hold the optical drive (CD-reader) connection to the device.
      Ask FixBot
    6. HP 15-ay052nr Keyboard and Touchpad Replacement: step 28, image 1 of 2 HP 15-ay052nr Keyboard and Touchpad Replacement: step 28, image 2 of 2
      • Remove the two (2) speakers located on the botten edge of the keyboard cover.
      • Along the edge that the touch-pad board and hard drive is located.
      Ask FixBot
    7. HP 15-ay052nr Keyboard and Touchpad Replacement: step 29, image 1 of 1
      • Make sure there is nothing else attached to the keyboard cover so all that remains is the keyboard and touch-pad.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 922
