HP 15-ay052nr Battery Replacement
    1. HP 15-ay052nr Battery Replacement, Battery: step 1, image 1 of 1
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      Ask FixBot
    2. HP 15-ay052nr Battery Replacement: step 2, image 1 of 1
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      Ask FixBot
    3. HP 15-ay052nr Battery Replacement: step 3, image 1 of 1
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 74
All Time: 1,043
