HP 15-ay014dx Wireless Card Replacement
    1. HP 15-ay014dx Wireless Card Replacement, Battery: step 1, image 1 of 1
      • Disconnect device from power source and power down.
      Ask FixBot
    2. HP 15-ay014dx Wireless Card Replacement: step 2, image 1 of 1
      • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
      Ask FixBot
    3. HP 15-ay014dx Wireless Card Replacement: step 3, image 1 of 1
      • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
      • Gently grasp the battery and pull it back away from the device and yourself.
      Ask FixBot
    1. HP 15-ay014dx Wireless Card Replacement, Optical Drive: step 4, image 1 of 1
      • Close the laptop and lay it down with the bottom facing up.
      • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
      Ask FixBot
    2. HP 15-ay014dx Wireless Card Replacement: step 5, image 1 of 1
      • Grip the optical drive and gently pull it out.
      Ask FixBot
    1. HP 15-ay014dx Wireless Card Replacement, Wireless Card: step 6, image 1 of 1
      • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
      Ask FixBot
    2. HP 15-ay014dx Wireless Card Replacement: step 7, image 1 of 2 HP 15-ay014dx Wireless Card Replacement: step 7, image 2 of 2
      • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
      Ask FixBot
    3. HP 15-ay014dx Wireless Card Replacement: step 8, image 1 of 2 HP 15-ay014dx Wireless Card Replacement: step 8, image 2 of 2
      • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
      Ask FixBot
    4. HP 15-ay014dx Wireless Card Replacement: step 9, image 1 of 1
      • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
      Ask FixBot
    5. HP 15-ay014dx Wireless Card Replacement: step 10, image 1 of 1
      • carefully pull the card of its slot.
      Ask FixBot
Drake Scoville
578 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 83
All Time: 793
