Up to 20% off select tools
HP 15-ay014dx RAM Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
94
All Time:
1,353
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to safely remove the RAM in your HP 15-ay014dx laptop for replacement.
    1. HP 15-ay014dx RAM Replacement, Battery: step 1, image 1 of 1
      • Disconnect device from power source and power down.
      Ask FixBot
    2. HP 15-ay014dx RAM Replacement: step 2, image 1 of 1
      • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
      Ask FixBot
    3. HP 15-ay014dx RAM Replacement: step 3, image 1 of 1
      • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
      • Gently grasp the battery and pull it back away from the device and yourself.
      Ask FixBot
    1. HP 15-ay014dx RAM Replacement, Optical Drive: step 4, image 1 of 1
      • Close the laptop and lay it down with the bottom facing up.
      • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
      Ask FixBot
    2. HP 15-ay014dx RAM Replacement: step 5, image 1 of 1
      • Grip the optical drive and gently pull it out.
      Ask FixBot
    1. HP 15-ay014dx RAM Replacement, RAM: step 6, image 1 of 1
      • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
      Ask FixBot
    2. HP 15-ay014dx RAM Replacement: step 7, image 1 of 2 HP 15-ay014dx RAM Replacement: step 7, image 2 of 2
      • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
      Ask FixBot
    3. HP 15-ay014dx RAM Replacement: step 8, image 1 of 2 HP 15-ay014dx RAM Replacement: step 8, image 2 of 2
      • Undo the clips holding the RAM in place using the plastic opening tool.
      Ask FixBot
    4. HP 15-ay014dx RAM Replacement: step 9, image 1 of 1
      • Carefully pull out the RAM from the motherboard.
      Ask FixBot
7 other people completed this guide.
Author
with
Drake Scoville
578 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 94
All Time: 1,353
