HP 15-ay014dx Heat sink Replacement
    1. HP 15-ay014dx Heat sink Replacement, Battery: step 1, image 1 of 1
      • Disconnect device from power source and power down.
      Ask FixBot
    2. HP 15-ay014dx Heat sink Replacement: step 2, image 1 of 1
      • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
      Ask FixBot
    3. HP 15-ay014dx Heat sink Replacement: step 3, image 1 of 1
      • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
      • Gently grasp the battery and pull it back away from the device and yourself.
      Ask FixBot
    1. HP 15-ay014dx Heat sink Replacement, Optical Drive: step 4, image 1 of 1
      • Close the laptop and lay it down with the bottom facing up.
      • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
      Ask FixBot
    2. HP 15-ay014dx Heat sink Replacement: step 5, image 1 of 1
      • Grip the optical drive and gently pull it out.
      Ask FixBot
    1. HP 15-ay014dx Heat sink Replacement, Wireless Card: step 6, image 1 of 1
      • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
      Ask FixBot
    2. HP 15-ay014dx Heat sink Replacement: step 7, image 1 of 2 HP 15-ay014dx Heat sink Replacement: step 7, image 2 of 2
      • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
      Ask FixBot
    3. HP 15-ay014dx Heat sink Replacement: step 8, image 1 of 2 HP 15-ay014dx Heat sink Replacement: step 8, image 2 of 2
      • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
      Ask FixBot
    4. HP 15-ay014dx Heat sink Replacement: step 9, image 1 of 1
      • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
      Ask FixBot
    5. HP 15-ay014dx Heat sink Replacement: step 10, image 1 of 1
      • carefully pull the card of its slot.
      Ask FixBot
    1. HP 15-ay014dx Heat sink Replacement, Heat sink: step 11, image 1 of 1
      • Remove the four screws holding the heatsink on.
      Ask FixBot
    2. HP 15-ay014dx Heat sink Replacement: step 12, image 1 of 1
      • Carefully pry the heat sink up and out of position to un-stick it from the thermal paste.
      • When reassembling, follow these steps on How to Apply Thermal Paste underneath the heatsink.
      Ask FixBot
Drake Scoville
578 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 704
