HP 15-ay014dx Hard Drive Disk Replacement
    1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: step 1, image 1 of 1
      • Disconnect device from power source and power down.
      Ask FixBot
    2. HP 15-ay014dx Hard Drive Disk Replacement: step 2, image 1 of 1
      • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
      Ask FixBot
    3. HP 15-ay014dx Hard Drive Disk Replacement: step 3, image 1 of 1
      • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
      • Gently grasp the battery and pull it back away from the device and yourself.
      Ask FixBot
    1. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: step 4, image 1 of 1
      • Close the laptop and lay it down with the bottom facing up.
      • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
      Ask FixBot
    2. HP 15-ay014dx Hard Drive Disk Replacement: step 5, image 1 of 1
      • Grip the optical drive and gently pull it out.
      Ask FixBot
    1. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: step 6, image 1 of 2 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: step 6, image 2 of 2
      • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
      Ask FixBot
    2. HP 15-ay014dx Hard Drive Disk Replacement: step 7, image 1 of 3 HP 15-ay014dx Hard Drive Disk Replacement: step 7, image 2 of 3 HP 15-ay014dx Hard Drive Disk Replacement: step 7, image 3 of 3
      • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
      • Pull the back cover off.
      Ask FixBot
    3. HP 15-ay014dx Hard Drive Disk Replacement: step 8, image 1 of 3 HP 15-ay014dx Hard Drive Disk Replacement: step 8, image 2 of 3 HP 15-ay014dx Hard Drive Disk Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
      • Pull out the SATA power ribbon using the tweezers.
      Ask FixBot
    4. HP 15-ay014dx Hard Drive Disk Replacement: step 9, image 1 of 2 HP 15-ay014dx Hard Drive Disk Replacement: step 9, image 2 of 2
      • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
      • Remove the hard drive.
      Ask FixBot
    5. HP 15-ay014dx Hard Drive Disk Replacement: step 10, image 1 of 1
      • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
      Ask FixBot
6 other people completed this guide.
Jimmy Huynh
263 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 29
All Time: 2,432
