HP 15-ay011nr Fan Replacement
    1. HP 15-ay011nr Fan Replacement, Battery: step 1, image 1 of 1
      • Slide the two battery lock latches on the back of the device to the “unlock” position.
      Ask FixBot
    2. HP 15-ay011nr Fan Replacement: step 2, image 1 of 1
      • Lift the battery upward to remove it from the device.
      Ask FixBot
    1. HP 15-ay011nr Fan Replacement, Back Panel: step 3, image 1 of 1
      • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
      • There should be 10 in total, be sure to keep them together!
      Ask FixBot
    2. HP 15-ay011nr Fan Replacement: step 4, image 1 of 1
      • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
      Ask FixBot
    3. HP 15-ay011nr Fan Replacement: step 5, image 1 of 2 HP 15-ay011nr Fan Replacement: step 5, image 2 of 2
      • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
      • Place the adhesive side up as you will need to place them back after your replacement is complete.
      Ask FixBot
    4. HP 15-ay011nr Fan Replacement: step 6, image 1 of 2 HP 15-ay011nr Fan Replacement: step 6, image 2 of 2
      • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
      • Be sure to keep the screws together!
      Ask FixBot
    5. HP 15-ay011nr Fan Replacement: step 7, image 1 of 1
      • Carefully remove the back panel from the device.
      • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
      Ask FixBot
    1. HP 15-ay011nr Fan Replacement, Fan: step 8, image 1 of 2 HP 15-ay011nr Fan Replacement, Fan: step 8, image 2 of 2
      • There are two 5/16 in. screws adjacent from each other that secure the fan to the device. Use the PH1 phillips-head screwdriver to remove them.
      • Be sure to keep them together!
      Ask FixBot
    2. HP 15-ay011nr Fan Replacement: step 9, image 1 of 2 HP 15-ay011nr Fan Replacement: step 9, image 2 of 2
      • Lift the clear plastic strip holding down the fan and lift the fan out of place.
      Ask FixBot
    3. HP 15-ay011nr Fan Replacement: step 10, image 1 of 2 HP 15-ay011nr Fan Replacement: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use your fingers or tweezers to pinch both sides of the connector and remove the fan from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 99
All Time: 1,956
