Up to 20% off select tools
HP 15-af123cl RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
53
All Time:
924
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
Introduction
Go to step 1 ↓
Do you need to replace your RAM on your HP 15-af123cl? If your processing speed is slowing down, this could be the issue. This guide explains how to replace the RAM.
Before we start replacing the RAM, let's cover some precautionary steps. First, we want to make sure the reason for the slow processing is not a program taking up all the memory space. To check, go to the task manager to verify that no open programs are slowing the computer down because it's using significant memory. If a program uses large amounts of memory, right-click and select "End Program." Test the computer to verify if the problem has been resolved. If the issue persists, we may need to replace the RAM.
You should also check that the RAM is set in place correctly (once your laptop is open.) Compare the RAM to the pictures provided below. If RAM is not flush, follow the instructions below and close the laptop to see if it is the issue. If the problem persists, redo the previous precautions and begin the RAM replacement instructions.
To start the RAM replacement process, verify if you are using ESD-safe tools and ESD-Band to prevent damage to the computer. To ensure your data is safe, back up your computer so that no data is lost.
Before beginning the repair, completely shut down the computer and disconnect the charging cable.
    1. HP 15-af123cl RAM Replacement, Battery: step 1, image 1 of 2 HP 15-af123cl RAM Replacement, Battery: step 1, image 2 of 2
      • Push the slider with a lock symbol to the right to unlock the battery.
      Ask FixBot
    2. HP 15-af123cl RAM Replacement: step 2, image 1 of 1
      • Push the slider with a battery symbol to the left to push the battery out slightly.
      • Pull the battery out fully now that it is released.
      Ask FixBot
    1. HP 15-af123cl RAM Replacement, Back Cover: step 3, image 1 of 1
      • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP 15-af123cl RAM Replacement: step 4, image 1 of 3 HP 15-af123cl RAM Replacement: step 4, image 2 of 3 HP 15-af123cl RAM Replacement: step 4, image 3 of 3
      • Turn the laptop over and open the lid.
      • Use an opening tool to pry the bottom cover from the body of the laptop.
      Ask FixBot
    3. HP 15-af123cl RAM Replacement: step 5, image 1 of 2 HP 15-af123cl RAM Replacement: step 5, image 2 of 2
      • Close and turn over the laptop again.
      • Pull the back cover up to remove it from the laptop.
      Ask FixBot
    1. HP 15-af123cl RAM Replacement, RAM: step 6, image 1 of 1
      • Press the metal brackets on either side of the RAM outwards.
      Ask FixBot
    2. HP 15-af123cl RAM Replacement: step 7, image 1 of 1
      • Remove the RAM from the laptop.
      Ask FixBot
Author
with
Victoria Santos
704 Reputation
6 Guides authored
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 53
All Time: 924
