HP 15-af123cl Optical Drive Replacement
    1. HP 15-af123cl Optical Drive Replacement, Battery: step 1, image 1 of 2 HP 15-af123cl Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Push the slider with a lock symbol to the right to unlock the battery.
      Ask FixBot
    2. HP 15-af123cl Optical Drive Replacement: step 2, image 1 of 1
      • Push the slider with a battery symbol to the left to push the battery out slightly.
      • Pull the battery out fully now that it is released.
      Ask FixBot
    1. HP 15-af123cl Optical Drive Replacement, Optical Drive: step 3, image 1 of 2 HP 15-af123cl Optical Drive Replacement, Optical Drive: step 3, image 2 of 2
      • Remove the single screw that holds in the optical drive using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP 15-af123cl Optical Drive Replacement: step 4, image 1 of 1
      • Slide the optical drive out of the laptop.
      Ask FixBot
Victoria Santos
704 Reputation
6 Guides authored
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 59
All Time: 441
