HP 15-af123cl Fan Replacement
    1. HP 15-af123cl Fan Replacement, Battery: step 1, image 1 of 2 HP 15-af123cl Fan Replacement, Battery: step 1, image 2 of 2
      • Push the slider with a lock symbol to the right to unlock the battery.
      Ask FixBot
    2. HP 15-af123cl Fan Replacement: step 2, image 1 of 1
      • Push the slider with a battery symbol to the left to push the battery out slightly.
      • Pull the battery out fully now that it is released.
      Ask FixBot
    1. HP 15-af123cl Fan Replacement, Back Cover: step 3, image 1 of 1
      • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP 15-af123cl Fan Replacement: step 4, image 1 of 3 HP 15-af123cl Fan Replacement: step 4, image 2 of 3 HP 15-af123cl Fan Replacement: step 4, image 3 of 3
      • Turn the laptop over and open the lid.
      • Use an opening tool to pry the bottom cover from the body of the laptop.
      Ask FixBot
    3. HP 15-af123cl Fan Replacement: step 5, image 1 of 2 HP 15-af123cl Fan Replacement: step 5, image 2 of 2
      • Close and turn over the laptop again.
      • Pull the back cover up to remove it from the laptop.
      Ask FixBot
    1. HP 15-af123cl Fan Replacement, Fan: step 6, image 1 of 1
      • Remove all seven screws from the fan and heat sink using a Phillips #000 screwdriver.
      Ask FixBot
    2. HP 15-af123cl Fan Replacement: step 7, image 1 of 1
      • Remove the heat sink from the laptop.
      Ask FixBot
    3. HP 15-af123cl Fan Replacement: step 8, image 1 of 2 HP 15-af123cl Fan Replacement: step 8, image 2 of 2
      • Disconnect the fan cables from the motherboard using an opening tool.
      Ask FixBot
    4. HP 15-af123cl Fan Replacement: step 9, image 1 of 1
      • Remove the fan from the laptop.
      Ask FixBot
Victoria Santos
704 Reputation
6 Guides authored
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 67
All Time: 738
