HP 15-af013cl Motherboard Replacement
    1. HP 15-af013cl Motherboard Replacement, Battery: step 1, image 1 of 1
      • Start off by flipping the laptop on its back.
      Ask FixBot
    2. HP 15-af013cl Motherboard Replacement: step 2, image 1 of 3 HP 15-af013cl Motherboard Replacement: step 2, image 2 of 3 HP 15-af013cl Motherboard Replacement: step 2, image 3 of 3
      • Push the two spring-loaded tabs inward.
      • Once unlatched, pull the battery out of its compartment.
      Ask FixBot
    1. HP 15-af013cl Motherboard Replacement, Motherboard: step 3, image 1 of 1
      • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
      • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
      Ask FixBot
    2. HP 15-af013cl Motherboard Replacement: step 4, image 1 of 2 HP 15-af013cl Motherboard Replacement: step 4, image 2 of 2
      • Remove the optical disk drive from the side of the laptop.
      Ask FixBot
    3. HP 15-af013cl Motherboard Replacement: step 5, image 1 of 1
      • Lift off the bottom cover, exposing the motherboard and other components underneath.
      Ask FixBot
    4. HP 15-af013cl Motherboard Replacement: step 6, image 1 of 2 HP 15-af013cl Motherboard Replacement: step 6, image 2 of 2
      • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
      • Disconnect the fan connector from the motherboard.
      Ask FixBot
    5. HP 15-af013cl Motherboard Replacement: step 7, image 1 of 1
      • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
      Ask FixBot
    6. HP 15-af013cl Motherboard Replacement: step 8, image 1 of 3 HP 15-af013cl Motherboard Replacement: step 8, image 2 of 3 HP 15-af013cl Motherboard Replacement: step 8, image 3 of 3
      • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
      • Remove the Wi-Fi card and cables.
      Ask FixBot
    7. HP 15-af013cl Motherboard Replacement: step 9, image 1 of 1
      • Carefully lift out the motherboard from the laptop.
      Ask FixBot
3 other people completed this guide.
Stephen Perreira
808 Reputation
6 Guides authored
Cal Poly, Team S8-G6, Banghart Fall 2017 Member of Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
5 Members
72 Guides authored
1 Guide Comment
i need motherboard hp model:15-bs127ne
elbetel ashenafi - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 124
All Time: 2,774
