HP 15-af013cl Hard Drive Replacement
    1. HP 15-af013cl Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Start off by flipping the laptop on its back.
      Ask FixBot
    2. HP 15-af013cl Hard Drive Replacement: step 2, image 1 of 3 HP 15-af013cl Hard Drive Replacement: step 2, image 2 of 3 HP 15-af013cl Hard Drive Replacement: step 2, image 3 of 3
      • Push the two spring-loaded tabs inward.
      • Once unlatched, pull the battery out of its compartment.
      Ask FixBot
    1. HP 15-af013cl Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
      • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
      Ask FixBot
    2. HP 15-af013cl Hard Drive Replacement: step 4, image 1 of 2 HP 15-af013cl Hard Drive Replacement: step 4, image 2 of 2
      • Remove the optical disk drive from the side of the laptop.
      Ask FixBot
    3. HP 15-af013cl Hard Drive Replacement: step 5, image 1 of 2 HP 15-af013cl Hard Drive Replacement: step 5, image 2 of 2
      • Lift off the bottom cover, exposing the motherboard and other components underneath.
      • Unscrew the four Phillips 3.0mm x 3.5mm screws on the hard drive bracket using the PH0 screwdriver.
      Ask FixBot
    4. HP 15-af013cl Hard Drive Replacement: step 6, image 1 of 2 HP 15-af013cl Hard Drive Replacement: step 6, image 2 of 2
      • Gently lift the hard drive from its position on the inside of the laptop.
      • Disconnect the ribbon cable from the hard drive.
      Ask FixBot
Stephen Perreira
808 Reputation
6 Guides authored
Cal Poly, Team S8-G6, Banghart Fall 2017 Member of Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 118
All Time: 1,751
