HP 15-ac158dx Keyboard Replacement
    1. HP 15-ac158dx Keyboard Replacement, Battery: step 1, image 1 of 1
      • Remove all external devices from the computer.
      • Remove the charging cord from the computer.
      Ask FixBot
    2. HP 15-ac158dx Keyboard Replacement: step 2, image 1 of 1
      • Turn off the computer by holding the power button.
      Ask FixBot
    3. HP 15-ac158dx Keyboard Replacement: step 3, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 3, image 2 of 2
      • To remove the battery, slide the left slider on the back to the unlocked position.
      Ask FixBot
    4. HP 15-ac158dx Keyboard Replacement: step 4, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 4, image 2 of 2
      • Push the right slider inwards.
      • Remove the battery out by pulling straight out and to the right.
      Ask FixBot
    1. HP 15-ac158dx Keyboard Replacement, Back Panel: step 5, image 1 of 3 HP 15-ac158dx Keyboard Replacement, Back Panel: step 5, image 2 of 3 HP 15-ac158dx Keyboard Replacement, Back Panel: step 5, image 3 of 3
      • Locate the CD Compartment panel and gently slide it out.
      Ask FixBot
    2. HP 15-ac158dx Keyboard Replacement: step 6, image 1 of 1
      • Remove the back of the laptop by unscrewing the screws shown.
      • Also remove the other 5 Phillips screws lining the back cover.
      Ask FixBot
    3. HP 15-ac158dx Keyboard Replacement: step 7, image 1 of 3 HP 15-ac158dx Keyboard Replacement: step 7, image 2 of 3 HP 15-ac158dx Keyboard Replacement: step 7, image 3 of 3
      • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
      • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
      Ask FixBot
    1. HP 15-ac158dx Keyboard Replacement, CD Compartment: step 8, image 1 of 3 HP 15-ac158dx Keyboard Replacement, CD Compartment: step 8, image 2 of 3 HP 15-ac158dx Keyboard Replacement, CD Compartment: step 8, image 3 of 3
      • Locate the CD Compartment as shown and gently slide it out.
      Ask FixBot
    1. HP 15-ac158dx Keyboard Replacement, Fan: step 9, image 1 of 3 HP 15-ac158dx Keyboard Replacement, Fan: step 9, image 2 of 3 HP 15-ac158dx Keyboard Replacement, Fan: step 9, image 3 of 3
      • Locate the Fan as shown.
      • Pull out the black cable, with four wires attached from its port.
      Ask FixBot
    2. HP 15-ac158dx Keyboard Replacement: step 10, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 10, image 2 of 2
      • Pull out the white cable wire from its port.
      • Unscrew the two black Phillips screws holding in the fan.
      Ask FixBot
    3. HP 15-ac158dx Keyboard Replacement: step 11, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 11, image 2 of 2
      • Remove fan.
      • Unscrew the two screws holding in the fan.
      Ask FixBot
    1. HP 15-ac158dx Keyboard Replacement, Motherboard: step 12, image 1 of 1
      • Remove the TEN 3mm screws.
      • Remove the ONE 9mm screw.
      Ask FixBot
    2. HP 15-ac158dx Keyboard Replacement: step 13, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 13, image 2 of 2
      • Locate the four ribbon clips.
      • Lift the grey part of the ribbon clips.
      • Pull the ribbon cable out and repeat this step for all four ribbon cables.
      • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
      Ask FixBot
    3. HP 15-ac158dx Keyboard Replacement: step 14, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 14, image 2 of 2
      • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
      Ask FixBot
    4. HP 15-ac158dx Keyboard Replacement: step 15, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    1. HP 15-ac158dx Keyboard Replacement, Keyboard: step 16, image 1 of 2 HP 15-ac158dx Keyboard Replacement, Keyboard: step 16, image 2 of 2
      • Remove the Hard Drive.
      Ask FixBot
    2. HP 15-ac158dx Keyboard Replacement: step 17, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 17, image 2 of 2
      • Lift up the cable port and place it to the side but do not remove completely from the laptop.
      • Remove the single Phillips screw securing it first.
      Ask FixBot
    3. HP 15-ac158dx Keyboard Replacement: step 18, image 1 of 3 HP 15-ac158dx Keyboard Replacement: step 18, image 2 of 3 HP 15-ac158dx Keyboard Replacement: step 18, image 3 of 3
      • Remove the VENDOR component.
      • Unscrew the single Phillips screw holding it to the frame first.
      Ask FixBot
    4. HP 15-ac158dx Keyboard Replacement: step 19, image 1 of 2 HP 15-ac158dx Keyboard Replacement: step 19, image 2 of 2
      • Using a plastic prying tools, remove the grey metal plate.
      • It will not come off easy, but do not force it off.
      Ask FixBot
    5. HP 15-ac158dx Keyboard Replacement: step 20, image 1 of 3 HP 15-ac158dx Keyboard Replacement: step 20, image 2 of 3 HP 15-ac158dx Keyboard Replacement: step 20, image 3 of 3
      • Locate the damaged keyboard and lift up with the prying tool to remove.
      Ask FixBot
      • To put everything back together and use your laptop with the new keyboard, follow the steps in REVERSE..
      • ENJOY :)
      Ask FixBot
7 other people completed this guide.
Onose Aigbe
390 Reputation
3 Guides authored
Baylor, Team S1-G2, Johnson Spring 2018 Member of Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Members
72 Guides authored
3 Guide Comments
Did you have to use soldering iron to melt the plastic rivets when putting back the keyboard?
Cheers.
Lo Yuk Fai - Reply Share
I have done these before and yes, using a soldering iron to melt the plastic rivets is a good method.
Richard Ness - Reply Share
Helpful. Too good!
David Dii Toke - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 157
All Time: 8,687
