Up to 20% off select tools
HP 15-ac142dx Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
65
All Time:
1,202
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HP 15-ac142dx Screen Replacement, Remove the bezel: step 1, image 1 of 1
      • Turn off your laptop and open the screen so it is perpendicular to the keyboard.
      • Insert an opening tool between the bezel and screen assembly, near the top right corner.
      Ask FixBot
    2. HP 15-ac142dx Screen Replacement: step 2, image 1 of 2 HP 15-ac142dx Screen Replacement: step 2, image 2 of 2
      • Once you've created a gap, gently lift and slide the tool down the sides and across the top of the seam until the bezel pops off.
      • While sliding, you'll hear clicks as the bezel clips release.
      • Continue moving the tool down to release it.
      Ask FixBot
    3. HP 15-ac142dx Screen Replacement, Remove the screen: step 3, image 1 of 2 HP 15-ac142dx Screen Replacement, Remove the screen: step 3, image 2 of 2
      • Remove the Phillips PM2.0×5.2 screws at the top of the screen with the #0 bit. This will allow the screen to pop off easily.
      • Once all the screws are removed, gently remove the screen from the lid.
      • Disconnect the ZIF connector on the back of the screen.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2 other people completed this guide.
Author
with
Nicole Mathieu
647 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 65
All Time: 1,202
