Up to 20% off select tools
HP 15-ac142dx Fan Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
60
All Time:
1,081
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HP 15-ac142dx Fan Replacement, Remove the battery: step 1, image 1 of 3 HP 15-ac142dx Fan Replacement, Remove the battery: step 1, image 2 of 3 HP 15-ac142dx Fan Replacement, Remove the battery: step 1, image 3 of 3
      • Turn off your laptop and flip it upside down onto a flat surface.
      • Slide the battery lock tabs towards each other to unlock the battery.
      • Lift the battery from the center and remove.
      Ask FixBot
    2. HP 15-ac142dx Fan Replacement, Reassembly information: step 2, image 1 of 1
      • To replace the battery:
      • Align the new battery with the cut-out in the laptop.
      • Insert the battery into it slot until you hear a "click" indicating the battery is fully seated.
      Ask FixBot
    1. HP 15-ac142dx Fan Replacement, Remove the fan: step 3, image 1 of 1
      • Use your Phillips screwdriver to remove the 10 screws in the bottom cover.
      Ask FixBot
    2. HP 15-ac142dx Fan Replacement: step 4, image 1 of 2 HP 15-ac142dx Fan Replacement: step 4, image 2 of 2
      • Flip the computer back over and use an opening tool to pry the keyboard up from the bottom of the computer.
      • Once the keyboard is removed, locate the fan.
      Ask FixBot
    3. HP 15-ac142dx Fan Replacement: step 5, image 1 of 2 HP 15-ac142dx Fan Replacement: step 5, image 2 of 2
      • Use your Phillips screwdriver to remove the two screws on either side of the fan.
      • Unplug the wire that is connected to the fan.
      • Remove the fan.
      Ask FixBot
Author
with
Nicole Mathieu
647 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 60
All Time: 1,081
