HP 15-ac142dx CMOS Battery Replacement
    1. HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 1, image 1 of 3 HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 1, image 2 of 3 HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 1, image 3 of 3
      • Turn off your laptop and flip it upside down onto a flat surface.
      • Slide the battery lock tabs towards each other to unlock the battery.
      • Lift the battery from the center and remove.
      Ask FixBot
    2. HP 15-ac142dx CMOS Battery Replacement, Reassembly information: step 2, image 1 of 1
      • To replace the battery:
      • Align the new battery with the cut-out in the laptop.
      • Insert the battery into it slot until you hear a "click" indicating the battery is fully seated.
      Ask FixBot
    1. HP 15-ac142dx CMOS Battery Replacement, Disassemble the laptop: step 3, image 1 of 1
      • Turn off your laptop and flip it over onto a flat surface.
      • Remove battery by sliding the battery lock.
      • Remove the 10 screws
      Ask FixBot
    2. HP 15-ac142dx CMOS Battery Replacement: step 4, image 1 of 2 HP 15-ac142dx CMOS Battery Replacement: step 4, image 2 of 2
      • Flip your laptop back over and use an opening tool to pry the keyboard up from the bottom case.
      • Locate the motherboard battery.
      Ask FixBot
    3. HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 5, image 1 of 2 HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 5, image 2 of 2
      • These photos are of a different device, but the procedure is identical.
      • Use the tip of a spudger to pry the motherboard battery out of its socket.
      • To install a new battery, insert it into its slot and press down firmly.
      Ask FixBot
Nicole Mathieu
647 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 34
Past 30 Days: 121
All Time: 1,643
