HP 15-ac142dx CD Drive Replacement
    1. HP 15-ac142dx CD Drive Replacement, Remove the battery: step 1, image 1 of 3 HP 15-ac142dx CD Drive Replacement, Remove the battery: step 1, image 2 of 3 HP 15-ac142dx CD Drive Replacement, Remove the battery: step 1, image 3 of 3
      • Turn off your laptop and flip it upside down onto a flat surface.
      • Slide the battery lock tabs towards each other to unlock the battery.
      • Lift the battery from the center and remove.
      Ask FixBot
    2. HP 15-ac142dx CD Drive Replacement, Reassembly information: step 2, image 1 of 1
      • To replace the battery:
      • Align the new battery with the cut-out in the laptop.
      • Insert the battery into it slot until you hear a "click" indicating the battery is fully seated.
      Ask FixBot
    1. HP 15-ac142dx CD Drive Replacement, Remove the CD drive: step 3, image 1 of 1
      • Use your Phillips screwdriver to remove the 10 screws from the bottom case.
      Ask FixBot
    2. HP 15-ac142dx CD Drive Replacement: step 4, image 1 of 2 HP 15-ac142dx CD Drive Replacement: step 4, image 2 of 2
      • Flip your laptop back over and lift open the screen so it is perpendicular to the keyboard.
      • Use an opening tool to pry the keyboard up from the bottom case.
      • The CD drive is located in the bottom case.
      • Slide the CD drive out of the bottom case.
      Ask FixBot
Nicole Mathieu
647 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 60
All Time: 805
