HP 15-ac121dx Wifi Card Replacement
    1. HP 15-ac121dx Wifi Card Replacement, Battery: step 1, image 1 of 1
      • Remove all external devices from the computer.
      • Remove the charging cord from the computer.
      Ask FixBot
    2. HP 15-ac121dx Wifi Card Replacement: step 2, image 1 of 1
      • Turn off the computer by holding the power button.
      Ask FixBot
    3. HP 15-ac121dx Wifi Card Replacement: step 3, image 1 of 2 HP 15-ac121dx Wifi Card Replacement: step 3, image 2 of 2
      • To remove the battery, slide the left slider on the back to the unlocked position.
      Ask FixBot
    4. HP 15-ac121dx Wifi Card Replacement: step 4, image 1 of 2 HP 15-ac121dx Wifi Card Replacement: step 4, image 2 of 2
      • Push the right slider inwards.
      • Remove the battery out by pulling straight out and to the right.
      Ask FixBot
    1. HP 15-ac121dx Wifi Card Replacement, Back Panel: step 5, image 1 of 2 HP 15-ac121dx Wifi Card Replacement, Back Panel: step 5, image 2 of 2
      • Place the laptop with the back panel facing up and the battery compartment facing away from you.
      • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
      Ask FixBot
    2. HP 15-ac121dx Wifi Card Replacement: step 6, image 1 of 1
      • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
      • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
      Ask FixBot
    3. HP 15-ac121dx Wifi Card Replacement: step 7, image 1 of 1
      • With the same orientation as the previous step, locate the bottom left corner.
      • Using a plastic opening tool, carefully pry off and remove the back panel.
      Ask FixBot
    1. HP 15-ac121dx Wifi Card Replacement, Wifi Card: step 8, image 1 of 3 HP 15-ac121dx Wifi Card Replacement, Wifi Card: step 8, image 2 of 3 HP 15-ac121dx Wifi Card Replacement, Wifi Card: step 8, image 3 of 3
      • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
      • Locate the Wifi card.
      • Using a Phillips #000 screwdriver, remove the 2mm screw securing the Wifi card in place.
      • Carefully remove the Wifi card.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 41
All Time: 941
