Up to 20% off select tools
HP 15-ac121dx Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
76
All Time:
1,553
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a straightforward guide on how to replace the HP 15-ac121dx Screen. The tools needed are the Phillips #000 Screwdriver and the iFixit Opening Tool. It is essential that this procedure is completed with care and attention to detail, since there are many components at risk of being damaged. The time needed to complete this procedure is approximately five minutes.
    1. HP 15-ac121dx Screen  Replacement, Battery: step 1, image 1 of 1
      • Remove all external devices from the computer.
      • Remove the charging cord from the computer.
      Ask FixBot
    2. HP 15-ac121dx Screen  Replacement: step 2, image 1 of 1
      • Turn off the computer by holding the power button.
      Ask FixBot
    3. HP 15-ac121dx Screen  Replacement: step 3, image 1 of 2 HP 15-ac121dx Screen  Replacement: step 3, image 2 of 2
      • To remove the battery, slide the left slider on the back to the unlocked position.
      Ask FixBot
    4. HP 15-ac121dx Screen  Replacement: step 4, image 1 of 2 HP 15-ac121dx Screen  Replacement: step 4, image 2 of 2
      • Push the right slider inwards.
      • Remove the battery out by pulling straight out and to the right.
      Ask FixBot
    1. HP 15-ac121dx Screen  Replacement, Screen: step 5, image 1 of 1
      • Open the laptop so that the screen is facing you.
      Ask FixBot
    2. HP 15-ac121dx Screen  Replacement: step 6, image 1 of 2 HP 15-ac121dx Screen  Replacement: step 6, image 2 of 2
      • With the screen facing you, use the plastic opening tool to remove the liner around the screen
      Ask FixBot
    3. HP 15-ac121dx Screen  Replacement: step 7, image 1 of 1
      • Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
      Ask FixBot
    4. HP 15-ac121dx Screen  Replacement: step 8, image 1 of 2 HP 15-ac121dx Screen  Replacement: step 8, image 2 of 2
      • Carefully remove the screen and place it face down on the keyboard.
      • Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
      Ask FixBot
    5. HP 15-ac121dx Screen  Replacement: step 9, image 1 of 2 HP 15-ac121dx Screen  Replacement: step 9, image 2 of 2
      • With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
      • You should see a 36-pin plug underneath the grounding tape.
      • Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
      Ask FixBot
2 other people completed this guide.
Author
with
Keefe White
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 76
All Time: 1,553
