HP 15-ac121dx Fan Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
82
All Time:
2,089
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach you how to replace the broken fan in your HP 15-ac121dx laptop to prevent the device from overheating.
Tools
    1. HP 15-ac121dx Fan Replacement, Battery: step 1, image 1 of 1
      • Remove all external devices from the computer.
      • Remove the charging cord from the computer.
      Ask FixBot
    2. HP 15-ac121dx Fan Replacement: step 2, image 1 of 1
      • Turn off the computer by holding the power button.
      Ask FixBot
    3. HP 15-ac121dx Fan Replacement: step 3, image 1 of 2 HP 15-ac121dx Fan Replacement: step 3, image 2 of 2
      • To remove the battery, slide the left slider on the back to the unlocked position.
      Ask FixBot
    4. HP 15-ac121dx Fan Replacement: step 4, image 1 of 2 HP 15-ac121dx Fan Replacement: step 4, image 2 of 2
      • Push the right slider inwards.
      • Remove the battery out by pulling straight out and to the right.
      Ask FixBot
    1. HP 15-ac121dx Fan Replacement, Back Panel: step 5, image 1 of 3 HP 15-ac121dx Fan Replacement, Back Panel: step 5, image 2 of 3 HP 15-ac121dx Fan Replacement, Back Panel: step 5, image 3 of 3
      • Locate the CD Compartment panel and gently slide it out.
      Ask FixBot
    2. HP 15-ac121dx Fan Replacement: step 6, image 1 of 1
      • Remove the back of the laptop by unscrewing the screws shown.
      • Also remove the other 5 Phillips screws lining the back cover.
      Ask FixBot
    3. HP 15-ac121dx Fan Replacement: step 7, image 1 of 3 HP 15-ac121dx Fan Replacement: step 7, image 2 of 3 HP 15-ac121dx Fan Replacement: step 7, image 3 of 3
      • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
      • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
      Ask FixBot
    1. HP 15-ac121dx Fan Replacement, Fan: step 8, image 1 of 3 HP 15-ac121dx Fan Replacement, Fan: step 8, image 2 of 3 HP 15-ac121dx Fan Replacement, Fan: step 8, image 3 of 3
      • Locate the Fan as shown.
      • Pull out the black cable, with four wires attached from its port.
      Ask FixBot
    2. HP 15-ac121dx Fan Replacement: step 9, image 1 of 2 HP 15-ac121dx Fan Replacement: step 9, image 2 of 2
      • Pull out the white cable wire from its port.
      • Unscrew the two black Phillips screws holding in the fan.
      Ask FixBot
    3. HP 15-ac121dx Fan Replacement: step 10, image 1 of 2 HP 15-ac121dx Fan Replacement: step 10, image 2 of 2
      • Remove fan.
      • Unscrew the two screws holding in the fan.
      Ask FixBot
Replace fan. To reassemble your device, follow these instructions in reverse order.
Onose Aigbe
390 Reputation
3 Guides authored
Baylor, Team S1-G2, Johnson Spring 2018 Member of Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 82
All Time: 2,089
