HP 15-ac121dx Back Panel Replacement
    1. HP 15-ac121dx Back Panel Replacement, Battery: step 1, image 1 of 1
      • Remove all external devices from the computer.
      • Remove the charging cord from the computer.
      Ask FixBot
    2. HP 15-ac121dx Back Panel Replacement: step 2, image 1 of 1
      • Turn off the computer by holding the power button.
      Ask FixBot
    3. HP 15-ac121dx Back Panel Replacement: step 3, image 1 of 2 HP 15-ac121dx Back Panel Replacement: step 3, image 2 of 2
      • To remove the battery, slide the left slider on the back to the unlocked position.
      Ask FixBot
    4. HP 15-ac121dx Back Panel Replacement: step 4, image 1 of 2 HP 15-ac121dx Back Panel Replacement: step 4, image 2 of 2
      • Push the right slider inwards.
      • Remove the battery out by pulling straight out and to the right.
      Ask FixBot
    1. HP 15-ac121dx Back Panel Replacement, Back Panel: step 5, image 1 of 2 HP 15-ac121dx Back Panel Replacement, Back Panel: step 5, image 2 of 2
      • Place the laptop with the back panel facing up and the battery compartment facing away from you.
      • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
      Ask FixBot
    2. HP 15-ac121dx Back Panel Replacement: step 6, image 1 of 1
      • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
      • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
      Ask FixBot
    3. HP 15-ac121dx Back Panel Replacement: step 7, image 1 of 1
      • With the same orientation as the previous step, locate the bottom left corner.
      • Using a plastic opening tool, carefully pry off and remove the back panel.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 80
All Time: 1,651
