Up to 20% off select tools
HP 15-R263DX Disassembly
Views: 7.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
102
All Time:
7,399
Comments: 1
1 comment on steps.
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
These are the required steps for disassembly in order to access internal components that may need replacement.
    1. HP 15-R263DX Disassembly, Battery: step 1, image 1 of 2 HP 15-R263DX Disassembly, Battery: step 1, image 2 of 2
      • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
      • Slide the battery out as shown in the picture.
      Ask FixBot
    1. HP 15-R263DX Disassembly, Optical Drive: step 2, image 1 of 2 HP 15-R263DX Disassembly, Optical Drive: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
      Ask FixBot
    2. HP 15-R263DX Disassembly: step 3, image 1 of 1
      • Gently slide the optical drive out of the side of the computer.
      Ask FixBot
    1. HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: step 4, image 1 of 2 HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: step 4, image 2 of 2
      • Locate the two corner grips on the hinge side of the computer.
      • Using a metal spudger, remove the two corner grips to reveal the screws.
      Ask FixBot
    2. HP 15-R263DX Disassembly: step 5, image 1 of 1
      • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
      Ask FixBot
    3. HP 15-R263DX Disassembly: step 6, image 1 of 1
      • Remove the 2 small screws that are on the bottom side of the disc tray slot.
      • These screws are shorter and wider than the others.
      Ask FixBot
    4. HP 15-R263DX Disassembly: step 7, image 1 of 2 HP 15-R263DX Disassembly: step 7, image 2 of 2
      • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
      • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
      • To disconnect the ribbon connector, flip up the black clip shown in the picture.
      • Gently pull the ribbon until disconnected.
      Ask FixBot
    5. HP 15-R263DX Disassembly: step 8, image 1 of 2 HP 15-R263DX Disassembly: step 8, image 2 of 2
      • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
      • Remove the 4 small screws shown in the picture.
      Ask FixBot
    6. HP 15-R263DX Disassembly: step 9, image 1 of 1
      • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
      • The face plate can then be lifted away from the computer.
      Ask FixBot
10 other people completed this guide.
Author
with
Dilan Johnson
729 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 102
All Time: 7,399
