Up to 20% off select tools
HP 15-R011DX RAM (Random Access Memory) Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
86
All Time:
1,654
Comments: 5
5 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The RAM of a device is key to its performance. Due to this, it is vital to knowing how to replace the RAM drive that is in your HP device. Always remember however that before replacing internal components that you should always back up the data in your device.
    1. HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: step 1, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: step 1, image 2 of 2
      • Slide the lock mechanism on the left side of the laptop to the right.
      Ask FixBot
    2. HP 15-R011DX RAM (Random Access Memory) Replacement: step 2, image 1 of 1
      • While holding the right slide mechanism, remove the battery from the laptop.
      • The battery is not pictured here because it is missing from this particular device.
      Ask FixBot
    1. HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 2 of 2
      • Flip the laptop over to reveal screw locations.
      • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
      Ask FixBot
    2. HP 15-R011DX RAM (Random Access Memory) Replacement: step 4, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement: step 4, image 2 of 2
      • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
      Ask FixBot
    3. HP 15-R011DX RAM (Random Access Memory) Replacement: step 5, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement: step 5, image 2 of 2
      • Remove the DVD drive from the laptop.
      • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
      Ask FixBot
    4. HP 15-R011DX RAM (Random Access Memory) Replacement: step 6, image 1 of 3 HP 15-R011DX RAM (Random Access Memory) Replacement: step 6, image 2 of 3 HP 15-R011DX RAM (Random Access Memory) Replacement: step 6, image 3 of 3
      • Flip the laptop and open.
      • Detach the keyboard by prying it free from the laptop using a spudger.
      • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
      • Disconnect the keyboard ribbon cable.
      Ask FixBot
    5. HP 15-R011DX RAM (Random Access Memory) Replacement: step 7, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement: step 7, image 2 of 2
      • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
      • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
      • Pry open the plastic casing using a spudger.
      • If struggling to remove the plastic case, check that all screws have been removed.
      Ask FixBot
    1. HP 15-R011DX RAM (Random Access Memory) Replacement, Hard Drive: step 8, image 1 of 1
      • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
      Ask FixBot
    2. HP 15-R011DX RAM (Random Access Memory) Replacement: step 9, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement: step 9, image 2 of 2
      • Pull the hard drive upwards and away from the laptop.
      • The hard drive should disconnect from its port on the motherboard as shown in the second image.
      Ask FixBot
    3. HP 15-R011DX RAM (Random Access Memory) Replacement: step 10, image 1 of 1
      • Flip the hard drive over.
      • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
      • Remove the mounting brace (silver bracket) from the hard drive.
      Ask FixBot
    1. HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: step 11, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: step 11, image 2 of 2
      • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
      Ask FixBot
    2. HP 15-R011DX RAM (Random Access Memory) Replacement: step 12, image 1 of 1
      • Remove the tape from the display connector attached to the motherboard.
      • Disconnect the display connector from the motherboard.
      Ask FixBot
    3. HP 15-R011DX RAM (Random Access Memory) Replacement: step 13, image 1 of 1
      • Remove one 4 mm Phillips #1 screw from the wireless chip.
      • Remove the wireless chip from the motherboard.
      Ask FixBot
    4. HP 15-R011DX RAM (Random Access Memory) Replacement: step 14, image 1 of 1
      • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
      • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
      Ask FixBot
    5. HP 15-R011DX RAM (Random Access Memory) Replacement: step 15, image 1 of 1
      • Slowly lift the motherboard out of the computer.
      • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
      • Disconnect the power connector from the motherboard as shown in the image.
      Ask FixBot
    1. HP 15-R011DX RAM (Random Access Memory) Replacement, RAM (Random Access Memory): step 16, image 1 of 1
      • Locate the RAM drive on the underside of the motherboard.
      Ask FixBot
    2. HP 15-R011DX RAM (Random Access Memory) Replacement: step 17, image 1 of 2 HP 15-R011DX RAM (Random Access Memory) Replacement: step 17, image 2 of 2
      • Push the locking tabs outward to release the RAM chip from the motherboard.
      Ask FixBot
    3. HP 15-R011DX RAM (Random Access Memory) Replacement: step 18, image 1 of 1
      • Remove the RAM chip by pulling the drive from the connectors.
      Ask FixBot
3 other people completed this guide.
Author
with
Joshua Brockman
368 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 86
All Time: 1,654
