Up to 20% off select tools
HP 15-R011DX Hard Drive Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
87
All Time:
2,128
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
A hard drive can be the source of many issues in a laptop computer. This means that it is important to know how to replace a hard drive. Before you decide to replace a hard drive, you should always attempt to back up your data to a secondary source so that nothing is lost in the process.
    1. HP 15-R011DX Hard Drive Replacement, Battery: step 1, image 1 of 2 HP 15-R011DX Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Slide the lock mechanism on the left side of the laptop to the right.
      Ask FixBot
    2. HP 15-R011DX Hard Drive Replacement: step 2, image 1 of 1
      • While holding the right slide mechanism, remove the battery from the laptop.
      • The battery is not pictured here because it is missing from this particular device.
      Ask FixBot
    1. HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 1 of 2 HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 2 of 2
      • Flip the laptop over to reveal screw locations.
      • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
      Ask FixBot
    2. HP 15-R011DX Hard Drive Replacement: step 4, image 1 of 2 HP 15-R011DX Hard Drive Replacement: step 4, image 2 of 2
      • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
      Ask FixBot
    3. HP 15-R011DX Hard Drive Replacement: step 5, image 1 of 2 HP 15-R011DX Hard Drive Replacement: step 5, image 2 of 2
      • Remove the DVD drive from the laptop.
      • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
      Ask FixBot
    4. HP 15-R011DX Hard Drive Replacement: step 6, image 1 of 3 HP 15-R011DX Hard Drive Replacement: step 6, image 2 of 3 HP 15-R011DX Hard Drive Replacement: step 6, image 3 of 3
      • Flip the laptop and open.
      • Detach the keyboard by prying it free from the laptop using a spudger.
      • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
      • Disconnect the keyboard ribbon cable.
      Ask FixBot
    5. HP 15-R011DX Hard Drive Replacement: step 7, image 1 of 2 HP 15-R011DX Hard Drive Replacement: step 7, image 2 of 2
      • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
      • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
      • Pry open the plastic casing using a spudger.
      • If struggling to remove the plastic case, check that all screws have been removed.
      Ask FixBot
    1. HP 15-R011DX Hard Drive Replacement, Hard Drive: step 8, image 1 of 1
      • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
      Ask FixBot
    2. HP 15-R011DX Hard Drive Replacement: step 9, image 1 of 2 HP 15-R011DX Hard Drive Replacement: step 9, image 2 of 2
      • Pull the hard drive upwards and away from the laptop.
      • The hard drive should disconnect from its port on the motherboard as shown in the second image.
      Ask FixBot
    3. HP 15-R011DX Hard Drive Replacement: step 10, image 1 of 1
      • Flip the hard drive over.
      • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
      • Remove the mounting brace (silver bracket) from the hard drive.
      Ask FixBot
3 other people completed this guide.
Author
with
Ethan Guillotte
517 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 87
All Time: 2,128
