Tools
Spudger4.9
Introduction
Go to step 1 ↓The cooling fan of any laptop or home computer ensures that the internal parts of the device do not overheat. For this reason it is important to make sure that your cooling fan is in working order and clean of dust. As with all disassembly guides, don’t forget to create a back up of your device’s hard drive.
Flip the laptop over to reveal screw locations.
Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
Using a Phillips #1 screwdriver, remove the three 5mm screws that secure the cooling fan assembly to the motherboard.
1 Guide Comment
It appears as though the jfan1 connection on the motherboard doesn’t have a plastic connector. I’ve bought a fan for this laptop to solve some overheating issues, but I can’t find anywhere to plug it in (I’m assuming that on similar models, the jfan1 connection would be the one to use). Is there any way that I can somehow plug my fan into this motherboard?
