Tools
Introduction
Go to step 1 ↓This guide will detail the removal of the onboard Random Access Memory (RAM) modules that are installed in the laptop.
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
