HP 15-BA078DX Hard Drive Replacement
    1. HP 15-BA078DX Hard Drive Replacement, Battery: step 1, image 1 of 3 HP 15-BA078DX Hard Drive Replacement, Battery: step 1, image 2 of 3 HP 15-BA078DX Hard Drive Replacement, Battery: step 1, image 3 of 3
      • Unclip the two latches on the bottom of the laptop.
      • Slide the battery straight out while holding the clip open.
      Ask FixBot
    1. HP 15-BA078DX Hard Drive Replacement, Disc Drive: step 2, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
      Ask FixBot
    2. HP 15-BA078DX Hard Drive Replacement: step 3, image 1 of 3 HP 15-BA078DX Hard Drive Replacement: step 3, image 2 of 3 HP 15-BA078DX Hard Drive Replacement: step 3, image 3 of 3
      • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
      Ask FixBot
    1. HP 15-BA078DX Hard Drive Replacement, Back Panel: step 4, image 1 of 1
      • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
      • Remember to remove the two screws under the rubber feet.
      Ask FixBot
    2. HP 15-BA078DX Hard Drive Replacement: step 5, image 1 of 3 HP 15-BA078DX Hard Drive Replacement: step 5, image 2 of 3 HP 15-BA078DX Hard Drive Replacement: step 5, image 3 of 3
      • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
      • You may need to flip the laptop over to unlatch all of the internal clips.
      Ask FixBot
    3. HP 15-BA078DX Hard Drive Replacement: step 6, image 1 of 3 HP 15-BA078DX Hard Drive Replacement: step 6, image 2 of 3 HP 15-BA078DX Hard Drive Replacement: step 6, image 3 of 3
      • Carefully pull the shell of the computer apart.
      Ask FixBot
    1. HP 15-BA078DX Hard Drive Replacement, Hard Drive: step 7, image 1 of 2 HP 15-BA078DX Hard Drive Replacement, Hard Drive: step 7, image 2 of 2
      • Using a black nylon spudger, disconnect the black connector that attaches the hard drive to the motherboard
      Ask FixBot
    2. HP 15-BA078DX Hard Drive Replacement: step 8, image 1 of 1
      • Using the Phillips #0 screwdriver, unscrew the three screws holding the hard drive down to the board.
      Ask FixBot
    3. HP 15-BA078DX Hard Drive Replacement: step 9, image 1 of 3 HP 15-BA078DX Hard Drive Replacement: step 9, image 2 of 3 HP 15-BA078DX Hard Drive Replacement: step 9, image 3 of 3
      • Remove the hard drive.
      Ask FixBot
    4. HP 15-BA078DX Hard Drive Replacement: step 10, image 1 of 2 HP 15-BA078DX Hard Drive Replacement: step 10, image 2 of 2
      • Using the Phillips #0 screwdriver, unscrew the four screws from the holding apparatus.
      Ask FixBot
3 other people completed this guide.
Benjamin DosSantos Jr
469 Reputation
4 Guides authored
3 Guide Comments
Can you provide the HDD model number for replacement? Also the model number or description of a compatible HDD with higher capacity.
Thank You
jcoengineer - Reply Share
Today, while disassembling my HP 15-BA078DX I had an issue trying to get the shell apart. I didn't realize that there was a screw under each rubber foot by the hinges. It would have saved me a whole lot of trouble had I known that. Very important to get those 2 screws out, otherwise you will risk breaking out the corner on the backside of the keyboard tray....... like I did. Fortunately for me, I was able to use some 2-part epoxy (the kind that works on plastic) to glue the hinge back down to the shell. Had the author pointed out those 2 screws in particular, in the pictorial, things would have gone way easier. Hopefully, this will help the next guy.
Eric S - Reply Share
btw.........you will also need a #1 phillips screwdriver if you plan on removing the hard drive.
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 84
All Time: 1,753
