HP 15-AF131DX Wireless Network Card Replacement
    1. HP 15-AF131DX Wireless Network Card Replacement, Battery: step 1, image 1 of 2 HP 15-AF131DX Wireless Network Card Replacement, Battery: step 1, image 2 of 2
      • Turn the computer upside down on a level surface.
      • Slide the battery lock to unlock the battery.
      • Slide the battery release latch. The latch will click when the battery is released.
      • Lift the battery from the middle to remove it from the computer.
      • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
      Ask FixBot
    1. HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: step 2, image 1 of 2 HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: step 2, image 2 of 2
      • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
      • Pull the CD/DVD drive outward to slide it away from the computer.
      Ask FixBot
    2. HP 15-AF131DX Wireless Network Card Replacement: step 3, image 1 of 1
      • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
      • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
      Ask FixBot
    3. HP 15-AF131DX Wireless Network Card Replacement: step 4, image 1 of 3 HP 15-AF131DX Wireless Network Card Replacement: step 4, image 2 of 3 HP 15-AF131DX Wireless Network Card Replacement: step 4, image 3 of 3
      • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
      • Gently pry the bezel from the face of the optical drive.
      • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
      Ask FixBot
    1. HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: step 5, image 1 of 2 HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: step 5, image 2 of 2
      • The first step of this process is to peel off two rubber feet from the bottom of the laptop.
      • Then remove twelve 8.8 mm screws using the Phillips #0 Screwdriver.
      Ask FixBot
    2. HP 15-AF131DX Wireless Network Card Replacement: step 6, image 1 of 3 HP 15-AF131DX Wireless Network Card Replacement: step 6, image 2 of 3 HP 15-AF131DX Wireless Network Card Replacement: step 6, image 3 of 3
      • Remove the bottom of the plastic case using a blue plastic opening tool.
      • The HP Wireless Network Card is found in Picture 3, circled in red.
      Ask FixBot
    3. HP 15-AF131DX Wireless Network Card Replacement: step 7, image 1 of 3 HP 15-AF131DX Wireless Network Card Replacement: step 7, image 2 of 3 HP 15-AF131DX Wireless Network Card Replacement: step 7, image 3 of 3
      • Remove one 3.3 mm screw using Phillips #0 screwdriver.
      • Pop off the connection wire by pulling the wire upwards off the stud on the HP Wireless Network Card.
      • Pull out the HP Wireless Network Card.
      Ask FixBot
Clayton Mettert
121 Reputation
1 Guide authored
IUPUI, Team S2-G2, Harley Fall 2018 Member of IUPUI, Team S2-G2, Harley Fall 2018
IUPUI-HARLEY-F18S2G2
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 68
All Time: 1,072
