HP 15-AF131DX Hard Drive Replacement
    1. HP 15-AF131DX Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP 15-AF131DX Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
      • Peel up the rubber feet near the hinges.
      • Remove the screw under each.
      Ask FixBot
    2. HP 15-AF131DX Hard Drive Replacement: step 2, image 1 of 2 HP 15-AF131DX Hard Drive Replacement: step 2, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
      • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
      • Gently lift the top surface of the bottom half of the laptop, revealing the hard drive.
      Ask FixBot
    3. HP 15-AF131DX Hard Drive Replacement: step 3, image 1 of 3 HP 15-AF131DX Hard Drive Replacement: step 3, image 2 of 3 HP 15-AF131DX Hard Drive Replacement: step 3, image 3 of 3
      • Remove the three screws that hold the hard drive in place.
      • Lift the hard drive slightly and disconnect the SATA hard drive connector to free the hard drive.
      • Remove the hard drive.
      Ask FixBot
10 other people completed this guide.
Anthony Martinez
556 Reputation
3 Guides authored
Cal Poly, Team S6-G2, Banghart Fall 2017 Member of Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 128
All Time: 6,405
