Up to 20% off select tools
HP 15-AF131DX Fan Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
99
All Time:
2,174
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The fan is an internal component of the notebook that prevents it from overheating after prolonged use. A fan is crucial for the notebook. Make sure the notebook has been unplugged and the battery removed.
    1. HP 15-AF131DX Fan Replacement, Fan: step 1, image 1 of 2 HP 15-AF131DX Fan Replacement, Fan: step 1, image 2 of 2
      • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
      • Peel up the rubber feet near the hinges.
      • Remove the screw under each.
      Ask FixBot
    2. HP 15-AF131DX Fan Replacement: step 2, image 1 of 2 HP 15-AF131DX Fan Replacement: step 2, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Turn the computer over and use a card to pry the space between the keyboard and bottom surface of the computer.
      • 'Work a plastic card or opening tool carefully around the three edges'' (excluding the side with the screen, which should be positioned at 90 degrees.
      • Gently lift the top surface of the bottom half of the laptop, revealing the fan.
      Ask FixBot
    3. HP 15-AF131DX Fan Replacement: step 3, image 1 of 2 HP 15-AF131DX Fan Replacement: step 3, image 2 of 2
      • To replace the fan remove the two screws that hold the fan in place.
      • Unplug the wire that connects the fan.
      • Remove the fan.
      Ask FixBot
3 other people completed this guide.
Author
with
Anthony Martinez
556 Reputation
3 Guides authored
Cal Poly, Team S6-G2, Banghart Fall 2017 Member of Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 99
All Time: 2,174
