HP 14-r008la Hard Disk Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
104
All Time:
5,813
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HP 14-r008la Hard Disk Replacement, Hard Disk: step 1, image 1 of 3 HP 14-r008la Hard Disk Replacement, Hard Disk: step 1, image 2 of 3 HP 14-r008la Hard Disk Replacement, Hard Disk: step 1, image 3 of 3
      • Shutdown the computer and remove the battery
      • Turn it right-side down, print a picture of its back cover
      Ask FixBot
    2. HP 14-r008la Hard Disk Replacement, Removing screws: step 2, image 1 of 3 HP 14-r008la Hard Disk Replacement, Removing screws: step 2, image 2 of 3 HP 14-r008la Hard Disk Replacement, Removing screws: step 2, image 3 of 3
      • Use double-sided tape to stick all the screws in its right place on the printed picture
      • Under the ram cover there is a screw, remove it
      • Dvd reader will come off when you remove its screw
      • Remove the two screws under the DVD reader
      Ask FixBot
    3. HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: step 3, image 1 of 3 HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: step 3, image 2 of 3 HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: step 3, image 3 of 3
      • Remove the two rubber feet beside battery place
      • Turn the laptop right-side up and open and insert a pry tool along the top-side keyboard until release it
      • Release the connector to which the keyboard cable is attached, and then disconnect the keyboard cable.
      Ask FixBot
    4. HP 14-r008la Hard Disk Replacement, Remove mother board cover: step 4, image 1 of 3 HP 14-r008la Hard Disk Replacement, Remove mother board cover: step 4, image 2 of 3 HP 14-r008la Hard Disk Replacement, Remove mother board cover: step 4, image 3 of 3
      • Remove three screws under keyboard
      • Don't forget the security protocol we followed in step 1 and 2
      • Insert pry tool around the cover in which touchpad used to be until release
      • First release the left side because the right has a clips which hold the cover.
      Ask FixBot
    5. HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: step 5, image 1 of 3 HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: step 5, image 2 of 3 HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: step 5, image 3 of 3
      • Release the connector to which the cable of two usb ports has been attaching
      • Remove the two usb ports and the speaker, and the two HDD screws then pull the HDD off
      • Remove metal frame in the first HDD and put it in the second
      Ask FixBot
5 other people completed this guide.
Internet Libre
740 Reputation
5 Guides authored
1 Guide Comment
Good job it did not work
Susan Oginni - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 104
All Time: 5,813
